BUGHIU Posted September 6, 2012 Share Posted September 6, 2012 Salutare,care v-ati lovit de acest sasiu ,va rog o idee legata de urmatorul lucru: am schimbat trafo linii si acum se arde instantaneu rezistenta de pe pinul 7 al trafo linii(3498)!! Atasez schema,componentele nu le mai trec: http://www.fileshare.ro/4.16206516881E+12 Quote Link to comment Share on other sites More sharing options...
naebv Posted September 6, 2012 Share Posted September 6, 2012 Cel mai probabil noul trafo linii este defect. O alta varianta ar fi sa-l porniti fara pipa de FIT la tub...sa nu aveti scurt pe FIT la TK, daca nu se mai arde R3498, testati sasiul pe alt tub. Quote Link to comment Share on other sites More sharing options...
gl 04 eyc Posted September 6, 2012 Share Posted September 6, 2012 Vad acolo si un C2845 la masa, l-ati intrebat de sanatate? Cu R3485 in aer aveti 13v? Sper sa nu fi gresit schema tv-ului. Incercati si cu Ug2 deconectata, cine stie... Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted September 6, 2012 Author Share Posted September 6, 2012 Mersi de interes si raspunsuri colegilor!! Le-am intrebat de ''sanatate'' pe toate ce le-am crezut suspecte si singurul bolnav este : trafo linii !! Am uitat sa specific ca cel ce l-am inlocuit a fost second-hand nu nou!! Quote Link to comment Share on other sites More sharing options...
naebv Posted September 6, 2012 Share Posted September 6, 2012 Procurati un AT2077/34 sau FBT6216 nou, cred ca gasiti la 20-30 lei. Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted September 8, 2012 Author Share Posted September 8, 2012 S-a rezolvat cu un FBT6216 nou!!!! Multumesc de raspunsuri!!Succesuri Quote Link to comment Share on other sites More sharing options...
Join the conversation
