valny Posted September 6, 2012 Share Posted September 6, 2012 Monitorul LG FLATRON L1718S, pe care il am la calculator, se comporta ciudat. Da sa porneasca sta o fractiune de secunda aprins si se stinge. Practic tuburile i se sting, ptr. ca daca ii dau on-off din buton se vede ecranul ptr. o fractiune de secunda. L-am desfacut l-am curatat si a luat-o. Dar nu stiu ptr. cat timp. Monitorul SAMSUNG l-am rezolvat cu o rezistenta pe pinii 5-6 la un integrat, dar LG-ul e total diferit. Ce ar putea sa aiba? Quote Link to comment Share on other sites More sharing options...
dan cod Posted September 6, 2012 Share Posted September 6, 2012 Lampile sau invertorul defect. Quote Link to comment Share on other sites More sharing options...
mircea888 Posted September 6, 2012 Share Posted September 6, 2012 Ceva condensatori umflati in sursa?Daca nu atunci e posibil ceva defect la invertor sau lampi. Vezi si lipiturile din zona invertorului. Quote Link to comment Share on other sites More sharing options...
leoncris Posted September 6, 2012 Share Posted September 6, 2012 Verifica mai intai toate tensiunile pe invertor si daca sunt ok , verifici pe rand CCFL_urile cu un invertor ... extern. http://www.scribd.com/doc/51616738/LG-L ... ice-manual Quote Link to comment Share on other sites More sharing options...
valny Posted September 7, 2012 Author Share Posted September 7, 2012 L-am desfacut din nou, fiind ca nu mai pornea si am gasit un condensator de 1000/25,umflat. L-am schimbat si a pornit. Sper sa tina. Multumesc celor care m-au ajutat Quote Link to comment Share on other sites More sharing options...
Join the conversation
