Guest Posted September 5, 2012 Share Posted September 5, 2012 Buna seara.Am un tv nipon ct20s care nu pleca,am gasit dioda zener din sursa r2m scurt ,am inlocuit-o si tv-ul a pornit ,numai ca peste citeva zile a venit inapoi cu u1=190 dioda initial e buna ,dar dupa 2,3 porniri crapa.Doresc o schema sa vad ce si cum tv-ul e cu str54041 pe sursa pca 84c 440 proc tda 4505 pe culoare,are sursa pe o placa separata..Multumesc. Quote Link to comment Share on other sites More sharing options...
leoncris Posted September 5, 2012 Share Posted September 5, 2012 http://www.site cu continut explicit.ro/540039.5 in loc de site , inlocuiesti cu ... g.i.r.l.s.h.a.r.e , fara puncte , evident sau http://elektrotanya.com/nippon_ct20c_ct ... nload.html sau http://www.hotfiles.ro/download/tvc_nip ... pdf/550516 Quote Link to comment Share on other sites More sharing options...
dan cod Posted September 5, 2012 Share Posted September 5, 2012 Acoloo STRul face figuri daca tot creste U1. Quote Link to comment Share on other sites More sharing options...
Join the conversation
