Guest 2sky Posted September 4, 2012 Share Posted September 4, 2012 Am un TV NEI 72cm model: S28 DELTA-4X. Televizorul functioneaza, problema este dimensiunea mica pe verticala si nu are semireglabili manual de utilizare nu am gasit si l-am primit fara telecomanda.Intrebare e posibil sa aiba in MENU,....ceva reglaje din telecomanda daca cumpar (PR106)telecomanda dedicata (destinata) astept raspuns. Va multumesc. 2SKY Quote Link to comment Share on other sites More sharing options...
doru tv Posted September 4, 2012 Share Posted September 4, 2012 posibil condensatori uscati in modul bv sau tensiunea de alimentare mica Quote Link to comment Share on other sites More sharing options...
leoncris Posted September 5, 2012 Share Posted September 5, 2012 Sasiu E9/A. Ia schema si ... la treaba. http://www.eserviceinfo.com/downloadsm/ ... ELUX_.html Quote Link to comment Share on other sites More sharing options...
Guest 2sky Posted April 7, 2013 Share Posted April 7, 2013 Sasiu E9/A.Ia schema si ... la treaba. Va multumesc Dl. leoncris acela este manualul de utilizare + schema . Am reusit sa intru in service menu dupa explicatiile din manual,folosind o telecomanda PR106 9,5Lei de la Mivarom 100% functionala. A durat atita deoarece am facut o comanda mai mare .Televizorul functioneaza perfect . inca odata va multumesc. 2SKY Quote Link to comment Share on other sites More sharing options...
Join the conversation
