Guest iuliani Posted September 4, 2012 Share Posted September 4, 2012 La pornire din standby/retea imaginea apare blurata pe circa 2/3 din ecran asa cum se vede din imagini.Si in lipsa semnalului video rastrul e la fel.Dupa un interval de circa 5-10 minute defectul dispare si televizoul functioneaza corect.Intervalul de timp in care persista defectul pare a fi direct proportional cu timpul in care tv. nu functioneaza,in sensul ca,dupa ce a functionat si a fost oprit un interval mic de timp,defectul dispare intr-un interval mai mic de timp.Nu am depanat pana acum un tv. lcd. Quote Link to comment Share on other sites More sharing options...
leoncris Posted September 4, 2012 Share Posted September 4, 2012 Verifica tensiunile si C_urile din ... sursa. Quote Link to comment Share on other sites More sharing options...
Guest iuliani Posted September 24, 2012 Share Posted September 24, 2012 Buna ziua,Ma poate ajuta cineva cu schema blocului de alimentare.Multumesc. Quote Link to comment Share on other sites More sharing options...
leoncris Posted September 25, 2012 Share Posted September 25, 2012 Slabe sperante sa gasesti.Spune totusi codul marcat pe ... modul. Quote Link to comment Share on other sites More sharing options...
Iachim Posted September 25, 2012 Share Posted September 25, 2012 Buna ziua,Ma poate ajuta cineva cu schema blocului de alimentare.Multumesc. Unde este componenta TV??dac merge vorba de sasiul fhilips LC7.2E poftimhttp://elektrotanya.com/philips_lc7.2e- ... nload.html Quote Link to comment Share on other sites More sharing options...
codrut Posted April 9, 2014 Share Posted April 9, 2014 am si eu un tv cu acelasi defect,s-a mai intalnit cineva cu acest defect? Quote Link to comment Share on other sites More sharing options...
ovy83 Posted April 9, 2014 Share Posted April 9, 2014 domnule Iuliane,incercati sa atinge-ti pamblicile cu driverile de pe ecran,posibil dezlipite de la caldura. Quote Link to comment Share on other sites More sharing options...
Join the conversation
