ozn_87 Posted September 3, 2012 Share Posted September 3, 2012 Salut ! Am un tv lcd OKI model v22aph la care sursa a fost reparata acum se aprinde foarte iluminat cu niste dungulete si pete la care in timp scade iluminozitatea...ce poate fi ? procesorul? Vad ca se incalzeste! va multumesc Quote Link to comment Share on other sites More sharing options...
ozn_87 Posted September 4, 2012 Author Share Posted September 4, 2012 Salut din nou ! Buba din fericire sa gasit, display-ul defect..mai exact partea electronca (t-con), vreau sa incerc sa inlocuesc integratul LRU4312X3A-AN..se merita? Quote Link to comment Share on other sites More sharing options...
Gabriel_S Posted September 4, 2012 Share Posted September 4, 2012 Sigur e defect t-con-ul? ce diagonala e pannel-ul, 22" ? Quote Link to comment Share on other sites More sharing options...
leoncris Posted September 4, 2012 Share Posted September 4, 2012 Fix ... 22 '' .Daca'l ai ... se merita. Quote Link to comment Share on other sites More sharing options...
ozn_87 Posted September 4, 2012 Author Share Posted September 4, 2012 Da ! Sa probat cu un alt display de 17" si merge perfect, sa verificat display-ul defect ,tensiunea de intrare este 5v , integratul se alimenteaza cu 3v totul ok...confirm ca este defect integratul ! Quote Link to comment Share on other sites More sharing options...
Join the conversation
