Marian C Posted September 3, 2012 Share Posted September 3, 2012 Buna, ma poate ajuta cineva cu schema tv sus mentionat ?multumesc Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted September 3, 2012 Share Posted September 3, 2012 Buna seara ! Nu prea credem ca o sa gasiti schema originala a tv-ului acesta,pentru ca am avut si noi unul asemanator la reparat si l-am facut mai mult asa....prin masuratori shimburi de piese etc......Poate sa va gasim ceva asemanator,dar pentru asta ne trebuie si noua mai multe detalii despre acest tv-u. Asteptam !! Quote Link to comment Share on other sites More sharing options...
cristybadea Posted September 3, 2012 Share Posted September 3, 2012 Sa nu mai deschid alt subiect,as vrea sa stiu modul cum se poate intra in SM la acest tv si ce trebuie schimbat pentru a putea adauga si norma DK.Cer scuze initiatorului acestui subiect pentru acest post.multumesc Quote Link to comment Share on other sites More sharing options...
Marian C Posted September 3, 2012 Author Share Posted September 3, 2012 are sonor, nu scoate tensiune g2, nici filamentul nu se aprinde, dar pe katozi cam 80 volti,eu banuiesc traf-ul linii sau nu e comandat bine tranz linii ? Quote Link to comment Share on other sites More sharing options...
coman ion Posted September 3, 2012 Share Posted September 3, 2012 Dati amanunte:sasiu,procesor,sursa ,etc.La hyundai modelele tv sunt varza. Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted September 3, 2012 Share Posted September 3, 2012 Buna seara ! Verificati daca nu cumva are vreun buton ascuns telecomanda pentru a intra in menu service . Succes ! Quote Link to comment Share on other sites More sharing options...
Marian C Posted September 3, 2012 Author Share Posted September 3, 2012 circuit integrat jungla+procesor r2j10192ga.....,mentionez ca si in standby se alimenteaza katozii cam la 120v,pe pcb scrie vsl-034-iep Quote Link to comment Share on other sites More sharing options...
coman ion Posted September 3, 2012 Share Posted September 3, 2012 Din pacate schema nu am dar o sa caut maine intrarea in sm.In stby pe catozi ajunge tens b+ prin bobina trafo linii(tens de 180v se obtine dintr-o priza superioara celei pe care intra b+)Faptul ca in mers scade inseamna ca si b+ scade deci consum mare in secundar. Quote Link to comment Share on other sites More sharing options...
cristronic Posted September 3, 2012 Share Posted September 3, 2012 Poate ajuta schema asta. Quote Link to comment Share on other sites More sharing options...
Marian C Posted September 3, 2012 Author Share Posted September 3, 2012 multumesc pt schema, e apropiata"In stby pe catozi ajunge tens b+ prin bobina trafo linii" pai e normal sa ajunga b+ pe bara de 180v? Quote Link to comment Share on other sites More sharing options...
Marian C Posted September 3, 2012 Author Share Posted September 3, 2012 am masurat si este scurt intre pin 10 al trafo linii (schema de mai sus ) si b+ ,eu zic ca e dus trafo linii primar Quote Link to comment Share on other sites More sharing options...
Marian C Posted September 4, 2012 Author Share Posted September 4, 2012 schema mai buna cu traful original este de royal 14 si pe fbt scriebsc24-01n4006ev si e normal sa existe legatura intre b+ si pinul 10 la acest fbt Quote Link to comment Share on other sites More sharing options...
dan cod Posted September 4, 2012 Share Posted September 4, 2012 TVul asta se manifesta normal.Deci si 80V pe catozi este normal(se face din U1)La TVul asta defectul este ca nu pleaca liniile.Deci acolo trebuie vazut de ce. Quote Link to comment Share on other sites More sharing options...
Marian C Posted September 4, 2012 Author Share Posted September 4, 2012 asa este am masurat baza emitor tranz linii si nimic, Quote Link to comment Share on other sites More sharing options...
dan cod Posted September 4, 2012 Share Posted September 4, 2012 Comanda de plecare din stby ia?se modifica ceva acolo?Daca da da finalul linii jos si pune osciloscopul in baza driver. Quote Link to comment Share on other sites More sharing options...
Join the conversation
