dorelb Posted September 3, 2012 Share Posted September 3, 2012 Nu am mai lucrat cu AVRStudio. Ieri m-am apucat sa recomplez un fisier, de pe un site rusesc si imi tot da eroare . Nu gasesc fisierul nicaieri. Poate cineva sa ma ajute ? Un printscreen mai jos . Quote Link to comment Share on other sites More sharing options...
ciocead4 Posted September 3, 2012 Share Posted September 3, 2012 Instaleaza si WinAVR, fisierul lipsa este parte a Avrlibc Quote Link to comment Share on other sites More sharing options...
dorelb Posted September 3, 2012 Author Share Posted September 3, 2012 L-am instalat . Si ce fac mai departe ? Quote Link to comment Share on other sites More sharing options...
godFather89 Posted September 4, 2012 Share Posted September 4, 2012 Nu trebuia instalat WinAVR. Problema e ca nu stie pentru care uC trebuie compilat. Mai exact care header sa il foloseasca din io.h.Vezi in proprietatile proiectului la Device, selectezi Change Device si alegi uC-ul tau (Atmega32?). Is mai multe metode de a rezolva problema, dar asta mi se pare cea mai corecta. Quote Link to comment Share on other sites More sharing options...
dorelb Posted September 4, 2012 Author Share Posted September 4, 2012 Da, am facut si asta. Am schimbat pozitia lui 0 si 1 de la atmega si nu gaseste nici mega16.h.Pun mai jos "C"-ul, poate mai incearca cineva sa-l rezolve. Quote Link to comment Share on other sites More sharing options...
Stefan Posted September 4, 2012 Share Posted September 4, 2012 ai aici http://mdoga.ru/Designs/Matrix%20clock% ... mega16.htm tot ce iti trebuie pentru proiect. zic totusi ca trebuie sa-l compilezi in CodeVisionAVR. pe xp sunt probleme cu denumirile in chirilica si orium nu il pot compila din cauza versiunii free a programului. http://i49.tinypic.com/21ki36b.jpg Quote Link to comment Share on other sites More sharing options...
dorelb Posted September 5, 2012 Author Share Posted September 5, 2012 De pe RADIOKOT am luat totul . Tot acelasi proiect cu asta, dar nu are ( hex ) pentru mega32. Am gasit ceva pe forum, dar nu stiu daca este bun . Quote Link to comment Share on other sites More sharing options...
MatyC Posted September 7, 2012 Share Posted September 7, 2012 @dorelb: Citisem postul tau pe zona de PIC si am cautat ceva pe goagle sa ma lamuresc si eu cumva cu problema ta. Am ajuns pe edabord http://www.edaboard.com/thread205755.html unde sunt cateva lamuriri legate de diferentele intre CodeVision si WinAvr. Sincer am auzit de ele dar nu le-am folosit niciodata. Cand am instalat Avr Studio am observat ca la compilator default am gcc (ala de compileaza si linux) insa nu am intrat in detalii. Nu am la dispozitie procesoare Atmel si din cauza asta nu aprofundez problema. Quote Link to comment Share on other sites More sharing options...
Join the conversation
