gaby57 Posted September 3, 2012 Share Posted September 3, 2012 Porneste din stby led-ul se face verde ,apare sunetul ,nu pornesc liniile ,verificat totul dupa topicurile deschise ,daca ating pinul 48 al junglei cu testerul instrumentului,instrumentul fiind pe Mohmi iar celalt tester la masa,pornesc liniile, totul e normal dar oprit si pornit nu mai pornesc liniile. Link to comment
iod2 Posted September 3, 2012 Share Posted September 3, 2012 sa discutat de un vagon de ori despre acest sasiu. nu ati avut timp sau chef sa cititi totschimbati condul C619 care e de 100n Link to comment
gaby57 Posted September 3, 2012 Author Share Posted September 3, 2012 daca citeai cu atentie am mentionat ca totul e verificat si schimbat dupa tot ce a fost scris despre acest defect Link to comment
Guest Posted September 3, 2012 Share Posted September 3, 2012 Ati verificat semnalul de sincro H pe pinul 48 - stv2248? Posibil sa fie defect. Link to comment
gaby57 Posted September 3, 2012 Author Share Posted September 3, 2012 jungla schimbata si porneste tot cu impuls,am uitat sa mentionez Link to comment
Guest Posted September 3, 2012 Share Posted September 3, 2012 Cititi cu multa atentie inceputul acestui topic: viewtopic.php?f=17&t=124195 Link to comment
gaby57 Posted September 5, 2012 Author Share Posted September 5, 2012 revin cu vechea problema ,tv porneste din stby led-ul se face verde apare sunet dar liniile nu pleaca in baza q 601 sunt 1,2 v ,daca ii dau un impuls porneste si totul e bine tensiuni bune in baza lui q 601 apar -1,2v,oprit nu mai porneste ,ramine in aceasi problema ,schimbat 3 jungle ,schimbat q 601 ,bu 808,c 619 -100n ,masurat si schimbat cam tot ce tine de acest defect ,nu stiu ce poate fi jungla nu porneste decit cu impuls pe rezistenta r424 Link to comment
dan cod Posted September 5, 2012 Share Posted September 5, 2012 C619 cati nano are?Quartzul de la jungla s-a schimbat? Link to comment
gaby57 Posted September 5, 2012 Author Share Posted September 5, 2012 c-ul are 100n masurat,am schimbat acum si quartzurile nimic nou Link to comment
dan cod Posted September 5, 2012 Share Posted September 5, 2012 Poate fi si jungla in ultima instanta.Verifica asa.cu SDA-SCL decuplate de la STV2248 , cu pinul 49 la masa si pinul 46 in aer trebuie sa porneasca impulsurile de sincro. Link to comment
gaby57 Posted September 5, 2012 Author Share Posted September 5, 2012 am schimbat 3 jungle aceaiasi problema Link to comment
dumitrescu_claudiu Posted September 6, 2012 Share Posted September 6, 2012 Eu am patit-o! Scoate ci verticalul! Link to comment
Guest Posted September 7, 2012 Share Posted September 7, 2012 Verificati urmatoarele componente: d611(smd), c636, r651, r646, r647, r649.De asemenea verificati tensiunea +26v, posibil lipsa datorita unui defect pe BV-tda8174 defect Link to comment
