raduhoria12 Posted September 2, 2012 Share Posted September 2, 2012 Am un televizor crt schneider stv1405-t, la care dupa pornire imaginea apare treptat. La inceput 3/4 din ecran este negru. De unde ar fi problema ? Quote Link to comment Share on other sites More sharing options...
gl 04 eyc Posted September 2, 2012 Share Posted September 2, 2012 Din baleiajul pe verticala. Schimbati condensatorii. Sasiul este, cred, CTN-BB. Quote Link to comment Share on other sites More sharing options...
leoncris Posted September 2, 2012 Share Posted September 2, 2012 http://archive.espec.ws/section908/file18755.htmlSchimba electroliticii C 2404,2415,2453.Verifica si tensiunile pe sursa : 107V,11V,5V si 23V pe C2453 sa fie corecte si ... stabile. Quote Link to comment Share on other sites More sharing options...
raduhoria12 Posted September 2, 2012 Author Share Posted September 2, 2012 Multumesc, am sa schimb condensatorii aia. Quote Link to comment Share on other sites More sharing options...
raduhoria12 Posted September 3, 2012 Author Share Posted September 3, 2012 Am schimbat condensatorii si a mers, multumesc frumos pt ajutor. Quote Link to comment Share on other sites More sharing options...
Join the conversation
