Ata Posted September 2, 2012 Share Posted September 2, 2012 Daca urmatorul tip de subiect nu se trateaza pe acest forum , va rog sa ma scuzati.Pe display-ul unui laptop a aparut imaginile din atasament.Cuplat alt monitor pe iesirea auxiliara VGA, se vede normal.Care pot fi cauzele?Multumec. Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted September 2, 2012 Share Posted September 2, 2012 Va salut ! Eu cred ca aveti probleme cu display-ul laptopului . Quote Link to comment Share on other sites More sharing options...
ronyku Posted September 2, 2012 Share Posted September 2, 2012 Salut!O situatie similara am intalnit-o la un monitor LCDbanda dintre modulul video si displayavea contact imperfect intr-unul din conectori Quote Link to comment Share on other sites More sharing options...
Ata Posted September 2, 2012 Author Share Posted September 2, 2012 Il pornesc fara HDD si acum imaginea apare. Am observat ca apare imaginea doar cand este alb - negru (logo Dell)Cand intra in Windows, imaginea se rupe. Quote Link to comment Share on other sites More sharing options...
Ata Posted September 5, 2012 Author Share Posted September 5, 2012 Ok, am depistat defectul si acum merge.Dupa ce am scris pe un forum la o firma de service laptop, care si la alt defect stia doar de 100E si atunci am rezolvat singur si acum mi-au zis tot 100E si eu tot singur am rezolvat.Un contact imperfect pe placa de baza langa ventilator, cum apasam usor cu ceva se stabiliza imaginea, erea o desincronizare pe verticala. Quote Link to comment Share on other sites More sharing options...
Join the conversation
