nikilapa86 Posted September 1, 2012 Share Posted September 1, 2012 Va salut!As dori daca se poate,sa ma ajutati cu oschema de tv. Ivory model JS-2130,nu stiu sasiul scrie ceva de genul: Js-2003-AO2,din ce am identificat,este echipat cu:D1710in sursa,D1651-bo,La7804a-bv si La76810 si Lc863332b.Tv-ul are un defect in bv.desincronizare.Va multumesc si va salut! Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted September 1, 2012 Share Posted September 1, 2012 Va salut ! Vedeti si dvs daca va ajuta schema aceasta atasata de mine .Succes !! Quote Link to comment Share on other sites More sharing options...
BUGHIU Posted September 1, 2012 Share Posted September 1, 2012 Nu stiu daca seamana: Daca nu ,intrati aici si vedeti ce se aseamana: http://www.electronica-pt.com/index.php ... o/id,5493/ CHINA+TV++2SC5148+LA8633XX+LA76810+LA4285+LA7840.pdf Quote Link to comment Share on other sites More sharing options...
nikilapa86 Posted September 1, 2012 Author Share Posted September 1, 2012 Multumesc d-lui Iordache, partea de bv. seamana.Multumesc tuturor ptr. ajutor! Quote Link to comment Share on other sites More sharing options...
naetv Posted September 1, 2012 Share Posted September 1, 2012 Cred ca mai aproape este CHINA SS1 AKIRA CT21DR9 - LC863320ALA76810 - TV SM http://www.electronica-pt.com/index.php ... n/id,2397/ si atentie la tranz 511 daca este 2sa1015 Quote Link to comment Share on other sites More sharing options...
nikilapa86 Posted September 1, 2012 Author Share Posted September 1, 2012 Da,merge si aceasta schema,intre timp am reparat tv-ul,necazul era in sursa.Inca odata multumesc! Quote Link to comment Share on other sites More sharing options...
Join the conversation
