Guest 3bbu Posted August 30, 2012 Share Posted August 30, 2012 Salut..! ma poate ajuta cineva ?! am sistem 2.1, si cand il pornesc merge cateva minute si apoi nu se mai aud boxele...,ci doar subwoofer-ul,mentionez ca in tot acest timp functioneaza "amp-ul" [volum 70%]. Apoi daca dau vol mai incet se aud din nou boxele. multumesc. Quote Link to comment Share on other sites More sharing options...
ChRS Posted August 31, 2012 Share Posted August 31, 2012 Ce model de sistem aveti? Ce putere are? Se aude vreun click dupa un anumit timp? Quote Link to comment Share on other sites More sharing options...
coman ion Posted August 31, 2012 Share Posted August 31, 2012 Ampl functioneaza la 70% dar sigur scoate semnal pe cele 2 iesiri de sateliti?Se poate verifica cu un alt difuzor sigur bun. Quote Link to comment Share on other sites More sharing options...
Join the conversation
