sorin0707 Posted August 29, 2012 Share Posted August 29, 2012 sursa tda 16846p,2sk2750,proc st 92195c/b1/pft,mem 24co8,jungla stv2248h,nu porneste,am schimbat tda16846 si 2sk 2750 nu se aprinde nici ledul de stand-by,am 300v pe cp06,nu am nici schema,am schimbat cp89 22m-50v cu unul de 47m-63v sa fie rau integratul?ms.Am incercat si cu bec si nimic. Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted August 29, 2012 Share Posted August 29, 2012 Va salut ! Dati un click aici : http://elektrotanya.com/vestel_and_masc ... nload.html sau aici : viewtopic.php?f=16&t=77376&p=1087416#p1087416 si descarcati service manual + schema . Succes !! Quote Link to comment Share on other sites More sharing options...
sorin0707 Posted August 29, 2012 Author Share Posted August 29, 2012 ms pt schema dar nu este pt92 este pt90,am gasit schema.ms Quote Link to comment Share on other sites More sharing options...
coman ion Posted August 29, 2012 Share Posted August 29, 2012 sursele cu tda16846 au in primar o rezistenta de 3,9 M (nu stiu pe dinafara reperul sau unde e pusa) care daca se intrerupe impiedica pornirea. Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 29, 2012 Share Posted August 29, 2012 Daca rezistenta de 3M9 este buna atunci CIul stift. Quote Link to comment Share on other sites More sharing options...
sorin0707 Posted August 29, 2012 Author Share Posted August 29, 2012 am rezolvat era o rez smd 47r arsa duce in pin 13 tda 16846 acum este ledu de stand-by aprins dar nu am telecomanda si din butoane nu porneste.Ce telecomanda merge la acest TV? Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted August 29, 2012 Share Posted August 29, 2012 Buna seara ! Eu asi zice sa incercati cu o telecomanda pilot P1696 sau clona ei.Succes ! Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 29, 2012 Share Posted August 29, 2012 Digital 1 si 2 este originala. Quote Link to comment Share on other sites More sharing options...
sorin0707 Posted August 29, 2012 Author Share Posted August 29, 2012 multumesc ffmult,multa sanatate la toti. Quote Link to comment Share on other sites More sharing options...
sorin0707 Posted August 30, 2012 Author Share Posted August 30, 2012 Am alta problema,cu scrinul la 300v porneste dar tubul nu se lumineaza, daca ii maresc la 335v se lumineaza sa fie tub defect?,se mai poate face ceva? Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 30, 2012 Share Posted August 30, 2012 Deci nu apare imaginea da?Incearca sa pui 3 rezistente de 1M intre 200V alimentarea video si fiecare catod.Apoi reglezi screenul cum trebuie sa fie imaginea ok.Asa am rezolvat multe. Quote Link to comment Share on other sites More sharing options...
sorin0707 Posted August 30, 2012 Author Share Posted August 30, 2012 ok,asa o sa fac multumesc mult. Quote Link to comment Share on other sites More sharing options...
Join the conversation
