Guest maginish Posted August 29, 2012 Share Posted August 29, 2012 Salutare . Am si eu o intrebare in legatura cu aceste boxe si anume puterea care o au . Cele mai multe le gasesti cu sigla de la Behringer galbena si scrie 2-Way 400-Watt Powered Loudspeaker With Integrated Sound Processor , iar modelul care il am eu este cu sigla neagra 2-Way 450-Watt Powered Loudspeaker With Integrated Sound Processor . Tind sa cred ca s-au produs 2 modele de b215a. Astept opinii. Quote Link to comment Share on other sites More sharing options...
sisu Posted August 29, 2012 Share Posted August 29, 2012 cu siguranta e acelasi produs....mai pe scurt,aceeasi marie cu alta palarie Quote Link to comment Share on other sites More sharing options...
Guest retturn_x Posted December 19, 2012 Share Posted December 19, 2012 150 w sinus per incinta Quote Link to comment Share on other sites More sharing options...
hpavictor Posted December 19, 2012 Share Posted December 19, 2012 La ce ti-ar putea folosi asemenea informatii ? Crezi ca iti poate confirma cineva ca in China s-a terminat stocul de plastic negru pentru sigle si au trecut la plastic galben sau invers ? Quote Link to comment Share on other sites More sharing options...
Join the conversation
