Guest Plus88 Posted August 29, 2012 Share Posted August 29, 2012 Am si eu o problema la o statie mai veche cu intrare dim 5 pini. Cand conectez calculatorul prin cablu adaptor din mufa 5 dim la jack 3.5mm, totul in regula. Cand conectez laptopul, sau altceva, prin acelasi cablu se aude doar basul foarte incet si distorsionat. Quote Link to comment Share on other sites More sharing options...
ChRS Posted August 31, 2012 Share Posted August 31, 2012 Posibil ca acel cablu sa aiba masa intrerupta, iar atuncia cand il conectezi la calculator, cablul sta in asa fel incat masa acestuia sa nu fie intrerupta. Quote Link to comment Share on other sites More sharing options...
Guest Plus88 Posted September 1, 2012 Share Posted September 1, 2012 Am incercat si cu alt cablu si se intampla la fel. Quote Link to comment Share on other sites More sharing options...
Guest Plus88 Posted September 15, 2012 Share Posted September 15, 2012 Mi-am dat seama pana la urma. La calculator am la iesire mufa jack cu masa, iar la laptop sau telefon nu am (fiind doar plastic). Cum as putea face masa la mufa jack mama? Quote Link to comment Share on other sites More sharing options...
dariuspopescu Posted September 15, 2012 Share Posted September 15, 2012 La calculator am la iesire mufa jack cu masa, iar la laptop sau telefon nu am .Daca mufele de la laptop sau telefon n-ar avea masa , ai auzi in amplificator un brum de "calitate" maxima ! Quote Link to comment Share on other sites More sharing options...
Guest Plus88 Posted September 15, 2012 Share Posted September 15, 2012 Bun deci am asa la laptop. Uploaded with ImageShack.us si la pc sau boxe de calc. Uploaded with ImageShack.us Quote Link to comment Share on other sites More sharing options...
Join the conversation
