paun nelu Posted August 28, 2012 Share Posted August 28, 2012 sasiu 10.3proc. video ars,tda4680/acum am imagine dar cu dungi albe subtire [rare nu ca la ug2 mare]initial am crezut ca sunt de la circ. de stingere dar nu e,cred ca este din cadre!!! rog un ajutor din partea voastra. Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 28, 2012 Share Posted August 28, 2012 Nu-i in BV ceva condi defect?Rezistenta de pe deflexia V e buna? Quote Link to comment Share on other sites More sharing options...
paun nelu Posted August 28, 2012 Author Share Posted August 28, 2012 daca te refery la rezistenta bobinei , da. Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 28, 2012 Share Posted August 28, 2012 NU la rezistenta bobinei ci in paralel cu deflexia V are o rezistenta de 2W de 220 sau 470 de ohmi.Cand aia se arde face dungi imaginea.Trebuie masurata cu un capat dezlipit ca altfel fenteaza rezistenta bobinei. Quote Link to comment Share on other sites More sharing options...
paun nelu Posted August 28, 2012 Author Share Posted August 28, 2012 este buna rezistenta , este de 220 ohmi Quote Link to comment Share on other sites More sharing options...
coman ion Posted August 28, 2012 Share Posted August 28, 2012 Dungile albe sunt pe tot ecranul sau doar in partea de sus? Quote Link to comment Share on other sites More sharing options...
paun nelu Posted August 29, 2012 Author Share Posted August 29, 2012 sunt pe tot ecranul,nu ca cele din cadre cand ai cond 100uf[tda3653]uscat Quote Link to comment Share on other sites More sharing options...
matryx Posted August 30, 2012 Share Posted August 30, 2012 tranzistorii si rezistentele de pe finalul video mai dau defectul asta.200 de volti are?TDA-ul este alimentat cu 8 volti? STIMA!!! Quote Link to comment Share on other sites More sharing options...
Join the conversation
