johans Posted August 26, 2012 Share Posted August 26, 2012 Buna ziua,Am acest Tv JVC AV-21QMG3 sasiu CG .... Tv-ul avea defecta sursa cu STR-W 5753A si pentru ca nu l-am gasit, m-am hotarat sa montez un UPS001,pe care l-am reglat la U1=110v .. Tv-ul a pornit si functioneaza bine ,dar are putin marita imaginea pe verticala ,nu mult si as dori sa intru in service menu ..Am cumparat telecomanda RM-C364GY pentru acet Tv si am incercat cu Display si Picture mode simultan dar nu merge . Va rog ,stie cineva cum se poate intra in menu service la acest tv ,sau se poate face un artificiu in jurul integratului AN5522...Atasez poze cu sasiul si telecomanda ...Va multumesc, Quote Link to comment Share on other sites More sharing options...
cristi71 Posted August 26, 2012 Share Posted August 26, 2012 daca nu puteti intra in service mode , mariti rezistenta care inchide circuitul de deflexie la masa (de regula are 1..2 ohmi) puneti in serie o rezistenta de 1 ohm. Quote Link to comment Share on other sites More sharing options...
johans Posted August 26, 2012 Author Share Posted August 26, 2012 Multumesc frumos ...dar la ce putere ? watti?Prima data mi-a reusit regland U1 ,dar mi-a luat foc montajul ups001,acum nu mai am curaj sa reglez de acolo.... Quote Link to comment Share on other sites More sharing options...
cristi71 Posted August 26, 2012 Share Posted August 26, 2012 pai vedeti de cat e cea originala..2W de regula. Quote Link to comment Share on other sites More sharing options...
dan-a2 Posted August 26, 2012 Share Posted August 26, 2012 Incercati sa refaceti sursa originala !! Quote Link to comment Share on other sites More sharing options...
johans Posted August 26, 2012 Author Share Posted August 26, 2012 Da intradevar merita reparata sursa originala,am cumprat recent si str-ul (14lei) ,dar are cateva diode mai ciudate ,masurate sunt ok..... ma gandesc sa nu se arda din nou str-ul. Quote Link to comment Share on other sites More sharing options...
cristi71 Posted August 26, 2012 Share Posted August 26, 2012 faptul ca dimensiunea cadre e marita denota o tensiune mai mica U1. ideal ar fi sa reparati sursa originala, insa daca nu se poate faceti modificarea care v am zis ca nu e nici un pericol. Quote Link to comment Share on other sites More sharing options...
johans Posted August 26, 2012 Author Share Posted August 26, 2012 Multumesc frumos .....am sa incerc str-ul ...daca nu aplic ce mi-ati spus... Quote Link to comment Share on other sites More sharing options...
johans Posted August 26, 2012 Author Share Posted August 26, 2012 Gata ,am pus la loc piesele pe care le eliminasem pentru montarea UPS001 si doua c-uri noi (4,7/50V si 47/35V) si Tv-ul a pornit cu str-ul nou ,dar si dioda MTZj36A-T2 a fost defecta din pinul 5 al str-ului..... Am facut rocada intre doua diode (ideea am luat-o de pe un forum rusesc),una am luat-o de langa selector si am montat-o in sursa ...iar cand am pornit tv-ul nu mergea cautarea ,doar cateva posturi prindea...am dat jos dioda zener si am pus una de 33v si merge perfect ,imaginea este incadrata bine.Si ....am mai avut o dioda pe care nu am gasit-o (D921) notata cu *5 in schema,dar am pus un BA159 ,sper sa fie ok acolo . Multumesc frumos pentru raspunsuri ,o seara frumoasa, Quote Link to comment Share on other sites More sharing options...
johans Posted August 31, 2012 Author Share Posted August 31, 2012 ....pana la urma am dat jos dioda Ba159 si am pus RGP10J ,m-am orientat dupa dioda alaturata D925 notata tot cu 5*... Quote Link to comment Share on other sites More sharing options...
Join the conversation
