Jump to content
Televizor proiectie SONY KDF-50E2010
 Share
codul de eroare e de la lampa sau switchul capacului lampii :there is a lamp cover switch which gives a 2 times flash when it is open."The sensor of the switch on the board being very sensitive, it may turn on under the influence of vibrations or it may be damage when it is to close to the door"You could see, feel it on the right side when youopen the lamp cover door.The cheapest way is to shorten itThe expensive way is to change it- ce am dat copy-paste mai sus e pentru switch - in cazul in care asa nu se rezolva solutia e schimbarea lampii
Link to comment
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
