korind Posted August 24, 2012 Share Posted August 24, 2012 buna ziua!am un tv samsung model ck 5081t cu procesor saa 5254p ,memorie 24lc04 care nu memoreaza programele, am rescris memoria dar la tot fara memorare.ma poate ajuta cineva cu un sfat? va multumesc Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 24, 2012 Share Posted August 24, 2012 Pune o memorie noua.Verifica daca ai alimentare si daca ai SCL si SDA pe pinii memoriei. Quote Link to comment Share on other sites More sharing options...
korind Posted August 24, 2012 Author Share Posted August 24, 2012 am pus memorie noua si nu se alimenteaza Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 24, 2012 Share Posted August 24, 2012 Pai daca nu se alimenteaza urmareste traseul de alimentare si vezi unde este intrerupt.Daca nu se alimenteaza memoria cum vrei sa mearga? Quote Link to comment Share on other sites More sharing options...
coman ion Posted August 25, 2012 Share Posted August 25, 2012 Acest tv nu are dump.Rescrierea mem e frectie la picior de lemn. Quote Link to comment Share on other sites More sharing options...
Join the conversation
