virgil_19 Posted August 24, 2012 Share Posted August 24, 2012 Va salut. Am mai primit acest TVC echipat cu : STR50103A , D1555 , TA8659AN , M34300-230SP AN5515 , 80011A/3206. Intrerupator princ. defect. Dupa strapare TVC porneste imag. sonor =OK ,dar nu simte nici o comanda din panoul frontal si nu recunoaste nici o telecomanda . +5v ajunge la panoul frontal, iar comut. +/-canal si+/- volum sunt OK Comutat. AV/TV trece in AV ,dar revine inTV. la eliberare. Va rog schema TVC si daca se poate ceva... indicatii. Posibil mem. def. ? Cu stima , Virgil. Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted August 24, 2012 Share Posted August 24, 2012 Va salut ! Dati un click aici : http://elektrotanya.com/megavision_dmq- ... nload.html . Succes !! Link to comment Share on other sites More sharing options...
dan cod Posted August 24, 2012 Share Posted August 24, 2012 Asta nu este legat de memorie.Daca atunci cand apesi TV/AV revine in AV posibil tasta asta sa fie dusa.Grija si cu telecomanda .Sigur este buna?Din cate tin minte telecomada lui este pozitia 68 canton R-18A07,IR354,P1830,Com3146. Link to comment Share on other sites More sharing options...
virgil_19 Posted August 24, 2012 Author Share Posted August 24, 2012 Va multumesc ptr. schema.TVC porneste in tv , la apasarea tastei TV/AV , trece in AV numai cat este apasata , la eliberare trece in TV. Cu stima , Virgil. PS. nu am telecomanda originala , am incercat mai multe universale, pe care nu le ,, simte". Link to comment Share on other sites More sharing options...
virgil_19 Posted August 24, 2012 Author Share Posted August 24, 2012 Va salut. Am inlocuit toate cele 5 contacte , acelasi simptom. Am verificat cablul de legatra cu panoul fronta = OK. Nu ,, simte" nici o comanda , ce ar putea sa fie defect? Cu stima , Virgil. LED rosu aprins. Link to comment Share on other sites More sharing options...
dan cod Posted August 24, 2012 Share Posted August 24, 2012 Eu zic sa cauti telecomanda lui ca poate muncesti degeaba.E mai deosebita telecomanda asta. Link to comment Share on other sites More sharing options...
virgil_19 Posted August 25, 2012 Author Share Posted August 25, 2012 Va salut. Va rog o schema - mai vizibila daca se poate . Nu stiu ce sa mai caut , unde poate fi defectul acestui TVC., prt. a functiona si din panoul frontal ? . Cu stima , Virgil. Link to comment Share on other sites More sharing options...
Guest nicoolass Posted August 25, 2012 Share Posted August 25, 2012 asta nu are cumva la butonul de retea un contact pentru start?ala nu trebuie sa ramana strapat Link to comment Share on other sites More sharing options...
virgil_19 Posted August 25, 2012 Author Share Posted August 25, 2012 Va salut. Corect, la intrerupatorul principal ON/ OFF este contactul de ,,initiere" . Daca este contact permanent pe el TVC porneste dar nu mai ,, simte" contactele +/- C si Vol. Cu stima , Virgil. Link to comment Share on other sites More sharing options...
dan cod Posted August 25, 2012 Share Posted August 25, 2012 Deci sa intelegem ca a fost defect contactul auxiliar? Link to comment Share on other sites More sharing options...
virgil_19 Posted August 26, 2012 Author Share Posted August 26, 2012 Va salut. Dupa cum am mai spus intrerup. prinvipal defect. Nu am avut acelasi tip ( fara contact de initiere ). Am srapat , initial contactul si din aceasta cauza nu simtea nici un contact de pe panoul frontal si nici o telecomanda.Acum am montat un micrintrerup. pe panoul frontal care are rolul contact. de initiere. Cu stima , Virgil. Link to comment Share on other sites More sharing options...
dan cod Posted August 26, 2012 Share Posted August 26, 2012 Pai nu cred ca s-a gandit nimeni eu cel putin nu ca strapat intrerupatorul vechi inseamna strapat contactul auxiliar. Link to comment Share on other sites More sharing options...
virgil_19 Posted August 26, 2012 Author Share Posted August 26, 2012 Va salut. Va multumesc pentru ajutor. Am gresit eu , dar la comut. defect masurat prin apasare contactul ,, parea" facut . Cu stima , Virgil. TVC rezolvat. Link to comment Share on other sites More sharing options...
Archived
