spinach Posted August 24, 2012 Share Posted August 24, 2012 saluatm , am desenat 3 variante ; care varianta credeti ca este mai corecta ? out tr.pdf Quote Link to comment Share on other sites More sharing options...
x_dadu Posted August 24, 2012 Share Posted August 24, 2012 nu ai nevoie de rezistenta la masa in baza tranzistorului. Varianta 3 e cea mai buna. Quote Link to comment Share on other sites More sharing options...
simplex Posted August 24, 2012 Share Posted August 24, 2012 Varianta 2 pare cea mai corecta (vezi: http://www.w9xt.com/page_microdesign_pt ... ching.html ) Rezistenta dintre baza tranzistorului si masa protejeaza releul la deschideri accidentale, de exemplu in momentul alimentarii schemei. Quote Link to comment Share on other sites More sharing options...
spinach Posted August 24, 2012 Author Share Posted August 24, 2012 ok; asa am sa o pun. Quote Link to comment Share on other sites More sharing options...
DarkAngel_Bv Posted August 25, 2012 Share Posted August 25, 2012 Cel mai bine folosesti tranzistor mos-fet cu sursa la masa si o rezistenta de 10-50K intre grila si sursa, + o rezistenta de 1-5K intre pinul atmega si grila (in caz ca se strapunge tranzistorul sa nu afecteze atmega).Tranzistorii bipolari cer mai mult curent in baza. Eu personal asa fac, si folosesc cei mai ieftini mos-feti pe care ii gasesc, chiar si SMD cu sarmulite lipite pe ei. Quote Link to comment Share on other sites More sharing options...
spinach Posted August 26, 2012 Author Share Posted August 26, 2012 din calculul meu , apare un curent de 0.5ma ; nu mi se pare mare , fata de datele de catalog . de oi gsi mos , am sa folosesc . inportant este cablajul care il proiectez. Quote Link to comment Share on other sites More sharing options...
one Posted September 1, 2012 Share Posted September 1, 2012 Varianta 2 mi se pare si mie corecta, chiar daca pentru led-uri eu folosesc varianta 3... Quote Link to comment Share on other sites More sharing options...
Join the conversation
