grasi Posted August 23, 2012 Share Posted August 23, 2012 sa traiti am si eu un tv pihilips sport nu mai scrie pe sasiu codul dar va dau codul dupa capac ,e problema cu sursa are sursa cu mc 44603ap si cel de pe alimentare nu il are dar cred ca este p4nc60 iar codul este 14pt138a/59r si mi ar trebui o schema de sursa va multumesc mult Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted August 23, 2012 Share Posted August 23, 2012 Buna seara ! Schema o puteti descarca de aici : http://www.eserviceinfo.com/downloadsm/ ... t138a.html dar atentie are 5 parti. Succes ! Quote Link to comment Share on other sites More sharing options...
grasi Posted August 23, 2012 Author Share Posted August 23, 2012 va multumesc domnu florin Quote Link to comment Share on other sites More sharing options...
grasi Posted August 23, 2012 Author Share Posted August 23, 2012 vreau sa va spun ca nu pot sa l deschid Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted August 23, 2012 Share Posted August 23, 2012 Pai le-ati descarcat pe toate 5 parti ? Quote Link to comment Share on other sites More sharing options...
grasi Posted August 23, 2012 Author Share Posted August 23, 2012 mii de scuze inca nu Quote Link to comment Share on other sites More sharing options...
grasi Posted August 23, 2012 Author Share Posted August 23, 2012 multumesc mult merge Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted August 23, 2012 Share Posted August 23, 2012 Bravo ! Ma bucur pentru dvs ca ati rezolvat problema . Quote Link to comment Share on other sites More sharing options...
Join the conversation
