florind Posted August 21, 2012 Share Posted August 21, 2012 Am un tv Edelstein nou cu sasiu Tousda TH-11135A.Tv-ul merge normal, executa absolut toate functiile. Totusi nu vrea sa schimbe posturile cu tastele P+ / P- nici din telecomanda, nici din butoanele tv. Procesorul primeste comanda, dar nu o executa.Posturile pot fi schimbate doar din tastele numerice ale telecomenzii.Stie cineva va rog de ce nu merg functiile P+ /P- ?Multumesc.Cu stima Florin Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 21, 2012 Share Posted August 21, 2012 Ai incercat sa schimbi dumpul? Quote Link to comment Share on other sites More sharing options...
leoncris Posted August 21, 2012 Share Posted August 21, 2012 Este telecomanda ... originala ?Celelalte "butoane" din panoul frontal lucreaza ? Quote Link to comment Share on other sites More sharing options...
florind Posted August 21, 2012 Author Share Posted August 21, 2012 Nu am schimbat inca dump. Deocamdata as vrea sa vad si parerile dvs.Telecomanda este originala si functioneaza bine. Toate butoanele de pe tv si telecomanda functioneaza corect. Doar P+ /P- nu merg. Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 21, 2012 Share Posted August 21, 2012 Spune procesorul exact sa iti dam un dump . Quote Link to comment Share on other sites More sharing options...
florind Posted August 21, 2012 Author Share Posted August 21, 2012 Pe procesor scrie asa:TDA11106PS/V3/3/AQ62TRG05455.1 18CT2969Multumesc Quote Link to comment Share on other sites More sharing options...
leoncris Posted August 21, 2012 Share Posted August 21, 2012 viewtopic.php?f=17&t=102629&p=930228&hilit=TDA11106PS%2FV3%2F3%2FAQ6#p930228 Quote Link to comment Share on other sites More sharing options...
florind Posted August 21, 2012 Author Share Posted August 21, 2012 Da,clar e de la dump. Cu oricare din cele 4 variante sugerate tv este 100% functional.Totusi cu niciuna din cele 4 variante nu reusesc sa calibrez (din service menu)dimensiunile imaginii.Dimensiunea este foarte mare pe verticala si foarte latita spre dreapta.Mai aveti cumva si alte dumpuri pentru acest procesor?Multumesc Quote Link to comment Share on other sites More sharing options...
Iachim Posted August 21, 2012 Share Posted August 21, 2012 Da,clar e de la dump. Cu oricare din cele 4 variante sugerate tv este 100% functional.Totusi cu niciuna din cele 4 variante nu reusesc sa calibrez (din service menu)dimensiunile imaginii.Dimensiunea este foarte mare pe verticala si foarte latita spre dreapta.Mai aveti cumva si alte dumpuri pentru acest procesor?Multumescpoftim inca citeva, dar spune, care parametri din service, tu le modifici, si nu ti se primeste? Quote Link to comment Share on other sites More sharing options...
florind Posted August 22, 2012 Author Share Posted August 22, 2012 Modific Vsize , dar nu e vorba ca nu le primeste ci ca nu sunt suficiente. Cu Vsize la minim imaginea e tot prea mare pe verticala.Cat despre latirea in dreapta pe orizontala nu pot decat sa o centrez din H position pentru ca nu am vazut vreun parametru prin care sa reduc dimensiunea pe orizontala. Dupa centrare imaginea este prea mare pe orizontala.Cu dumpul original dimensiunile imaginii sunt perfecte, dar dupa cum am spus nu merge P+ /P-Clar ca trebuie un dump adecvat acestui tv.Multumesc Quote Link to comment Share on other sites More sharing options...
florind Posted August 23, 2012 Author Share Posted August 23, 2012 Multumesc dlui Iachim, dar niciunul din dumpuri nu vrea sa mearga la acest tv Quote Link to comment Share on other sites More sharing options...
dan cod Posted August 24, 2012 Share Posted August 24, 2012 Am atasat si eu ceva dumpuri. Quote Link to comment Share on other sites More sharing options...
florind Posted August 24, 2012 Author Share Posted August 24, 2012 Multumesc si dlui Dan Cod, dar nici acestea nu rezolva problema. Tv functioneaza dar nu are sonor nici pe AV nici pe antena. Pe AV cu volum la maxim se aude o usoara caraiala, iar pe antema are ori sonor maxim ori deloc. Plus imaginea este foarte mare.Eu cred ca acest stift chinezesc nu a functionat corect din nastere Quote Link to comment Share on other sites More sharing options...
attilaa0 Posted August 24, 2012 Share Posted August 24, 2012 Buna seara.De ce nu scrii ce marca e TV-ul mai exact poate am eu un bin salvat.Respect Quote Link to comment Share on other sites More sharing options...
leoncris Posted August 25, 2012 Share Posted August 25, 2012 Bin_ul original este salvat ? Quote Link to comment Share on other sites More sharing options...
Join the conversation
