virgil_19 Posted August 2, 2012 Share Posted August 2, 2012 Va salut. Am primit acest TVC- Trinitron color care nu mai functioneaza. Este echipat cu : alim=STR F6654 , SAA5497PS/076 ,CXA2060AS , STV9379 , TDA9870 , TDA9817 , LM393N , final linii D2539 . Posibil sasiu=S601 ? . Am rugamintea , daca se poate , schema lui si ceva indicatii .Tub=M68KZT 70X. Cu stima , Virgil. Link to comment
zvasile Posted August 2, 2012 Share Posted August 2, 2012 ce anume nu mai functioneaza? sasiul este FE-1, http://www.eserviceinfo.com/downloadsm/ ... 2-FE1.html Link to comment
virgil_19 Posted August 3, 2012 Author Share Posted August 3, 2012 Multumesc ptr. schema domnului Vasile.Dupa cateva verificari , la pornire am observat ca din C633 (470pf/2kv) iese fum. La masurarea C. acesta indica o rezit. de 22 Ohm. D608=OK. Trebuie sa gasesc C. la 2Kv. ptr. al inlocui. Va tin la curent. Cu stima , Virgil. Link to comment
virgil_19 Posted August 3, 2012 Author Share Posted August 3, 2012 Va multumesc. TVC. rezolvat . Cu stima , Virgil. Link to comment
