spyry Posted July 28, 2012 Share Posted July 28, 2012 Salutare meseriasi .Am primit un tv Elite la care imediat dupa pornire apare pe ecran partea de jos mesajul scris cu rosu CHILD LOCK si in partea stinga sus apare FACTORY ,dupa aprox 5 secunde dispare child lock iar din factory ramane decat FAC si nu simte nimic nici din telecomanda nici din panoul frontal .Ce trebuie facut in acest caz pentru al debloca.? Link to comment
FLORIN IORDACHE Posted July 28, 2012 Share Posted July 28, 2012 Va salut ! TV Elite model..........sasiu...........nu scrie chiar nimic pe acest tv ?Asteptam !! Link to comment
dan cod Posted July 28, 2012 Share Posted July 28, 2012 Ce procesor si ce telecomanda are tvul? Link to comment
spyry Posted July 28, 2012 Author Share Posted July 28, 2012 Cer scuze ca nu am scris ce proc foloseste dar nu deschisesem capacul crezand ca este ceva simplu ca si la Zander de exemplu prin apsarea PP cateva secunde .Procesor M61266 TIP smd ;junglaM37160MB; sursa cu tranzistori ;Bv LA78040 memorie 24C08A.TIP TV14PAL. Link to comment
BUGHIU Posted July 28, 2012 Share Posted July 28, 2012 Cred ca e ....invers: M61266 este jungla si celalalt procesor!! Si e posibil sa aveti nevoie de un alt dump!! http://elektrotanya.com/microsonic_14tf ... nload.html Link to comment
