Guest lkaroly Posted July 10, 2012 Share Posted July 10, 2012 Dragi colegi va cer ajutorul ,referitor la o piesa din acest model de tvSasiu:C25N2V3 Proc TDA9351PS/N2/..Verticala:LA78040NSursa:5L0380RAm urmatoarea problema , amgasit circuitul integrat W431 in scurt notat pe placa IC702 si nu stiu ce este si de unde l-as putea gasi eventual daca are cine rog sa-mi trimita unu contra cost , Va multumesc anticipat. Link to comment
dan cod Posted July 10, 2012 Share Posted July 10, 2012 Capsula ca si BCul ?Nu-i cumva TL431 ?Este in sursa? Link to comment
cristybadea Posted July 10, 2012 Share Posted July 10, 2012 Merge fara probleme 24 TL431 Link to comment
Guest lkaroly Posted July 10, 2012 Share Posted July 10, 2012 Da este capsula ca BC-ul si este dupa surca pe B+ in circuit cu optocuplorul , dar daca merge TL-ul atunci pun TL, va multumesc foarte mult. Link to comment
