Guest adrian harhas Posted June 28, 2012 Share Posted June 28, 2012 Buna ziua v-as ruga frumos daca ma puteti ajuta cu o schema la tv orion tv20182si procesor Micronas MSP3400G B8 V3 si pe sasiu scrie BEKO electronicU99 190-06 V59110.As avea nevoie numai de schita pt. sursa deoarece a fost puscata si nu se mai vad valorile la rezistente si circuit integrat. Va multumesc si va doresc o zi buna. Link to comment
dan cod Posted June 28, 2012 Share Posted June 28, 2012 MSPul e procesorul de sunet nu procesorul tvului.Cu ce este facuta sursa? Link to comment
mariancalinescu Posted June 28, 2012 Share Posted June 28, 2012 Posibil Beko sasiu 14.2,dar pentru o identificare corecta spuneti cu ce integrate e facut tv-ul.MSP-ul e procesor sunet. Link to comment
Guest adrian harhas Posted June 28, 2012 Share Posted June 28, 2012 TDA 9563H/N1/3I smd Link to comment
dan cod Posted June 28, 2012 Share Posted June 28, 2012 Asta din atas ar trebui dupa cum zice si Marian.viewtopic.php?f=16&p=961087#p961087 Link to comment
