bebe2010 Posted June 14, 2012 Share Posted June 14, 2012 buna seara Are cineva schema sasiu-lui XDK 190-07 de pe un tv ORION as fi foarte recunoscator. Sau daca stie cineva dece nu mai vrea sa functioneze e mort complet. pun si cateva poze o seara buna Link to comment
zvasile Posted June 14, 2012 Share Posted June 14, 2012 sasiu K2,manualul service aici; http://www.electronica-pt.com/images/fb ... manual.pdf Link to comment
bebe2010 Posted June 15, 2012 Author Share Posted June 15, 2012 salut stie careva dece am 500v pe c651? sa fie puntea de dinaintea condensatorului de vina? Link to comment
dan cod Posted June 15, 2012 Share Posted June 15, 2012 Sigur este 500V acolo?Puntea nu are legatura. Link to comment
bebe2010 Posted June 15, 2012 Author Share Posted June 15, 2012 am masurat in cc si imi arata 493V de unde atatia volti nu stiu Link to comment
palcu ion Posted June 16, 2012 Share Posted June 16, 2012 ia un aparat de masura bun sau schimba bateria la asta Link to comment
tehtronics Posted June 16, 2012 Share Posted June 16, 2012 Sper ca n-ai masurat fata de masa sasiului !!!Masoara direct pe condensator...N-are cum sa fie atat de mare. Link to comment
bebe2010 Posted July 16, 2012 Author Share Posted July 16, 2012 am schimbat si bateria la aparatu' de masura, direct pe condensator am 493-496v,am mai schimbat c652 si r636 am verificat si diodele d611 si 621 dar tot mort ramane si tensiunea de pe c651 persista.sa se fi dus ICE1QS01? Link to comment
dan cod Posted July 16, 2012 Share Posted July 16, 2012 Daca tensiunea aia este reala nu-i exclus.Eu as elimina tot de acolo si as lasa doar puntea si condul mare sa vad cat este atunci tensiunea. Link to comment
petreelectronic Posted July 16, 2012 Share Posted July 16, 2012 daca ai fi avut 496V acolo sigur iti bubuia condensatorul in ochi. Pune aparatul pe volti curent continuu si o sa-ti dea aprox. 300v. Link to comment
bebe2010 Posted July 16, 2012 Author Share Posted July 16, 2012 da am pus pe cc si atat imi arata ,cred ca trebuie sa imi iau un aparat de masura nou Link to comment
bebe2010 Posted September 1, 2012 Author Share Posted September 1, 2012 In primul si-n primul rand va anunt ca mi-am luat alt aparat de masura si culmea am tot 493v si condu' nu bubuie si nici nu as vrea.m-am uitat pe schema si condu' e de 68uf/400v iar pe sasiu am 100uf/400v sa fie de la el tensiunea asa mare,am verificat celula snubber si pare in regula dar in chopper nu am tensiune, sa fie ic ars sau mosfetu'? Link to comment
BUGHIU Posted September 1, 2012 Share Posted September 1, 2012 496v cc?!?!? Nu l-ati bagat la.... 380vca?!?!?! Link to comment
cristi71 Posted September 1, 2012 Share Posted September 1, 2012 ori e prost condensatorul si arata testerul balarii..puneti altul de 100/400v si vedeti. Link to comment
naetv Posted September 1, 2012 Share Posted September 1, 2012 am tot 493v si condu' nu bubuie si nici nu as vrea.m-am uitat pe schema si condu' e de 68uf/400v iar pe sasiu am 100uf/400v sa fie de la el tensiunea asa mare,am verificat celula snubber si pare in regula dar in chopper nu am tensiune, sa fie ic ars sau mosfetu'?Poate fi ars orice , dupa cond , nu ar trebui sa ajunga la peste 490V decit daca :-Nu stiti sa masurati - sa folositi aparatul -Aparat defect -Tensiune foarte mare de retea - dar cum spunea cineva , pocnea condensatorul Cit este tensiunea alternativa la intrare ? in chopper nu am tensiune de pe cond plusul se duce la chopper prin FB601 - unde sa dispara ? sau nu este la iesire - tensiuni stabilizate ? Schema o aveti ? Link to comment
