cristybadea Posted June 12, 2012 Share Posted June 12, 2012 Bun gasit.La acest sasiu am gasit banalul defect de final linii si ci.cadre. Dupa schimbarea acestora impreuna cu conzii aferenti fiecarui etaj problema e urmatoarea.Tv-ul nu porneste decat cu tirist MCR 22 scos din circuit.In acest mod toate tensiunile sunt ok,doar b+ este 125v fata de 129v cat ar trebui(tub plat).Cu mcr22 in circuit tv pare a fi in st-bye doar ca b+ este 33v iar la actionarea butoanelor de P+ tlc sau bord tv nu porneste,b+ nu sare de 40v iar sursa scoate acelasi zgomot ca si in cazul in care finalul linii este in scurt. Link to comment
leoncris Posted June 12, 2012 Share Posted June 12, 2012 b+ 125v este OK .Rezistenta de 99K este verificata ?Celelalte tensiuni ,cum sunt ? Link to comment
cristybadea Posted June 12, 2012 Author Share Posted June 12, 2012 Si celelalte tensiuni sunt ok dar cu mcr22 scos din circuit,cu el in circuit b+40v iar celelalte variaza intre 2,2-2,6v iar tensiunea de 9v este de 7v si ceva Link to comment
leoncris Posted June 12, 2012 Share Posted June 12, 2012 De rezistenta , ce ne spui ? Link to comment
leoncris Posted June 12, 2012 Share Posted June 12, 2012 R817 , parca !"b+ 125v este OK .Rezistenta de 99K este verificata ?Celelalte tensiuni ,cum sunt ?" Link to comment
Guest Posted June 12, 2012 Share Posted June 12, 2012 Verifica R817=99k, asa cum a zis leoncris, mai mult ca sigur o ai "intinsa" - devalorizata. Link to comment
dan cod Posted June 12, 2012 Share Posted June 12, 2012 Daca are 125V U1 rezistenta aia este buna. Link to comment
sorin0707 Posted June 12, 2012 Share Posted June 12, 2012 posibil scurtcircuit intre R824 (5,6R/5W) si R624 (27R/3W)poate se ating una de cealalta si scurtcircuiteaza B+. Link to comment
niki4 Posted June 12, 2012 Share Posted June 12, 2012 Pune-i bec si vezi cum se comporta ?Daca merge pe bec verifica C caramea de 47n parca c811 din primarul sursei Link to comment
cristybadea Posted June 12, 2012 Author Share Posted June 12, 2012 Oameni buni,am spus ca fara mcr22 in circuit tv-ul functioneaza perfect(atat cat este posibil in regim de comanda fortata) are rastru si tensiunile sunt ok,deci nu mai este cazul sa banuiesc sursa,etajul linii,jungla etc.Cu mcr22 montat in circuit tv-ul se comporta cum am mentionat mai sus.Am mai observat ca,in momentul cand as putea considera ca este in modul of b+ are 33-35v iar sursa scoate sunetul specific de protectie la intensitate mica iar la trecerea tv-ului in onb+ nu creste de40v iar sunetul sursei creste in intensitate Link to comment
leoncris Posted June 12, 2012 Share Posted June 12, 2012 Omule , protectiile sunt pentru tensiune si curent si pot fi hardware (MC44608 cu componentele aferente) si/sau software (IC501 cu componentele ... aferente - O funcţie de software-ul controlat acţionează pe pin52 de IC501. Acest PIN-ul monitorizează feedback-ului din tensiunile 8V şi 5V prin D512, apoi compară acestea cu o valoare de referinţă Vref pre-stabilita de hardware-ul prin intermediul R545, R546 rezistori, R548.)Monitorizarea curentului absorbit de către receptor (sursa Q801) este returnat la punte redresoare printr-o rezistenta R807 de valoare mica. Deci ... Link to comment
naebv Posted June 12, 2012 Share Posted June 12, 2012 Incercati sa montati intre baza si emitorul lui Q802 un condensator de 4,7-10uF/40-63Vcc (+in baza, - la emitor), eventual schimbati Q802 din oficiu (presupun ca ati schimbat MCR22, optoculplor, filtraje, etc.) Link to comment
cristybadea Posted June 12, 2012 Author Share Posted June 12, 2012 mcr22 l-am schimbat.Optocuplorul inca nu dar,nu cred sa fie asta buba. Link to comment
doru tv Posted June 12, 2012 Share Posted June 12, 2012 inlocuiti c 4700mf fara a monta alt cond in paralel ! Link to comment
