Guest jungla Posted June 11, 2012 Share Posted June 11, 2012 Buna ziua d-lor,ma puteti ajuta cu acest tv? Nu porneste,pentru inceput ce ar trebui sa verific? Multumesc. Link to comment
dan cod Posted June 11, 2012 Share Posted June 11, 2012 Sursa de alimentare sa scoata tensiuni. Link to comment
Guest jungla Posted June 11, 2012 Share Posted June 11, 2012 Sursa STRW 6754 inlocuita.Lipsa alimentare,siguranta fuzibila este OK.In continuare ce ar fii necesar ca masuratori? Link to comment
dan cod Posted June 11, 2012 Share Posted June 11, 2012 Start are sursa? Scurt in secundare nu este? Link to comment
Guest jungla Posted June 11, 2012 Share Posted June 11, 2012 R-806 se pare ca e prajita rau de tot. Cum pot sa ajung la schema? Link to comment
Guest Posted June 11, 2012 Share Posted June 11, 2012 rectificare: http://www.eserviceinfo.com/downloadsm/ ... MX,RX.html http://www.eserviceinfo.com/downloadsm/ ... MX,RX.html revin 2:nici aici nu este schema? Link to comment
Guest jungla Posted June 11, 2012 Share Posted June 11, 2012 Cum facem d-lor,il ????? Link to comment
dan cod Posted June 11, 2012 Share Posted June 11, 2012 R806 are 0,18 ohmi.Daca e dusa clar CIul defect.Trebuie verificat optocuplorul,SEul neaparat Link to comment
Guest Posted June 11, 2012 Share Posted June 11, 2012 ridica schema de la adresa data de mine si fa o captura numai cu sursa sa discutam pe componente Link to comment
Guest jungla Posted June 11, 2012 Share Posted June 11, 2012 Am 1 1/2 de cand incerc sa iau nenorocita aia de schema. Link to comment
Guest jungla Posted June 11, 2012 Share Posted June 11, 2012 Sunt exact aici dar nu pot intra,naiba in ele calculatoare. Link to comment
Guest jungla Posted June 12, 2012 Share Posted June 12, 2012 ridica schema de la adresa data de mine si fa o captura numai cu sursa sa discutam pe componente Link to comment
leoncris Posted June 12, 2012 Share Posted June 12, 2012 Cam asta este ... sursa. Doc2.doc Presentation1.ppt Link to comment
Guest Posted June 12, 2012 Share Posted June 12, 2012 daca r806 este arsa se verifica mos-ul de putere din integrat,adica intre pinii 1 si 2 ai ic801 daca corespunde cu schema lui leoncrisasta nu inseamna si un scurt in secundar sau,si mai grav,traful de forta defect Link to comment
