Guest marius1234 Posted April 14, 2012 Share Posted April 14, 2012 Buna.Ma poate ajuta cineva sa gasesc un integrat de sistem genius 5005? Link to comment
Ghiurcuta Bogdan Posted April 14, 2012 Share Posted April 14, 2012 Ce integrat(ce are scris pe el)?ce model de genius? Link to comment
iod2 Posted April 14, 2012 Share Posted April 14, 2012 daca e ala de la butoanele de control.....e un microcontroler care trebuie programat. Link to comment
Guest marius1234 Posted April 16, 2012 Share Posted April 16, 2012 Sistem 5.1 Genius 5000.l-am bagat in priza si a puscat ceva.de atunci nu mai merge Link to comment
adyyo Posted April 16, 2012 Share Posted April 16, 2012 Ati verificat siguranta din spatele woofer-ului? Am patit si eu ceva de genul pe acelasi tip de sistem. L-am bagat in priza, a pocnit difuzorul de bas si s-a ars siguranta. Am pus una putin mai mare si nu am mai avut pb. de atunci. Sper sa fie asta problema. Link to comment
bluey Posted April 16, 2012 Share Posted April 16, 2012 E clar un integrat defect daca a puscat ceva :)TDA7294??Mai mult ca sigur ca nu o sa mai reusesti sa citesti ceva pe el.Sau mai intra in scurt condensatorii de deparazitare pusi in paralel pe diodele redresoare. Link to comment
Guest marius1234 Posted April 18, 2012 Share Posted April 18, 2012 L-am dus la un electrician si a zis ca s-a ars integratul si nu gaseste piesa sa o comande pt ca e made in china ceva de genu. Link to comment
dan-a2 Posted April 18, 2012 Share Posted April 18, 2012 Posteaza seria integratului aici !! Link to comment
BUGHIU Posted April 18, 2012 Share Posted April 18, 2012 L-am dus la un electrician si a zis ca s-a ars integratul si nu gaseste piesa sa o comande pt ca e made in china ceva de genu.Incercati la un ...electronist; la electrician....mai greu!!!S-a ars integratul...; dar care,ca sant mai multe!!! Link to comment
george_bc Posted April 18, 2012 Share Posted April 18, 2012 Electricianul schimba becuri, trage fire... Link to comment
BUGHIU Posted April 18, 2012 Share Posted April 18, 2012 Face el mai multe nu doar astea,dar....fiecare cu treaba lui !! Link to comment
Guest Posted April 18, 2012 Share Posted April 18, 2012 Ultima oara cand am reparat eu un Genius d-asta, avea in scurt mizeriile alea de conzi, care-s plantati in paralel cu diodele redresoare... i-am schimbat, am schimbat siguranta, si merge impecabil si astazi, dupa 2 ani.Mergi la un electronist, sa faca o diagnoza corecta... altfel, pierzi vremea cu vorbe goale... Link to comment
Guest mybambucha Posted April 19, 2012 Share Posted April 19, 2012 Buna searaAm un sistem genius SW-HF5.1 5000 si am o problema cu subwooferul. Intr-o zi am auzit o pocnitura in cutia subwooferului si de atunci nu a mai mers deloc bass-ul. Celalalte iesiri merg perfect. Care ar putea fi cauzele?Multumesc! Link to comment
iod2 Posted April 19, 2012 Share Posted April 19, 2012 daca nu faci nici un fel de masuratoare....mai bine nu mai posta nimic. Link to comment
