ivanflorin Posted January 13, 2012 Share Posted January 13, 2012 LA MULTI ANI pe acest an si multa SANATATE tuturor .... Am un tvc elite model 21ES11,procesor TDA11105PS/V3/3La reparat acum ~3saptamini la stadiul urmator;ledu-ul era rosu ,din tast nu pornea, la fel si din telec...capacul jos si am masurat U1..u2,3,4...tv-ul a pornit ..am refacut ceva lipituri reci ...la-m batut ,la-m zdruncinat ,sasiul torsionat cit de cit...functiona fara probleme...Azi a revenit ''clientul ''cu tv-ul in aceeas situatie...led rosu,nf tast,nf telec,...dat capacul jos si masurat U1=112v,u2,3,4....tv-ul functioneaza brici..ce sa fie ....va multumes anticipat pt ajutor.. Link to comment
petreelectronic Posted January 13, 2012 Share Posted January 13, 2012 Cel mai probabil o lipitura pacatoasa. Examinati cu atentie si refaceti mai ales la procesor. Link to comment
ivanflorin Posted January 13, 2012 Author Share Posted January 13, 2012 logic asa ar trebui sa fie ...calea de stand-by ....dar am refacut ceva lipituri si teama este ca peste~ 1 luna vine cu acelas defecttv-ul functioneaza stas la ora asta....il opresc, ii dau drumu la intervale de 1.......30minute ..el functioneaza si cu sasiul ''batut''..... Link to comment
palcu ion Posted January 13, 2012 Share Posted January 13, 2012 schimba c pe 12v si eventual pe 5v sau de unde face alim la procesor Link to comment
leoncris Posted January 13, 2012 Share Posted January 13, 2012 Ia schemuta si refa masuratorile incepand cu primarul sursei. http://www.eserviceinfo.com/downloadsm/ ... 4ES11.html Link to comment
ivanflorin Posted January 13, 2012 Author Share Posted January 13, 2012 multam pt schema dn-lui leoncris si celor 2 colegi pt implicare dar tv-ul in incapatinarea lui continua sa functioneze ireprosabil...ce tens. sa verific daca este in regula imaginea ....revin cu acest subiect imediat ce gasesc rezolvarea...sper sa nu fie asta.. Link to comment
dan cod Posted January 13, 2012 Share Posted January 13, 2012 Sigur cand pui capacul la loc se torsioneaza placa de aceea nu merge cu el pus ci face figuri.Lipiturile aiurea pot fi la smduri si e mai greu de vazut.Dupa parerea mea sigur este din lipituri sau traseu care se intrerupe la torsionare. Link to comment
ivanflorin Posted January 13, 2012 Author Share Posted January 13, 2012 ms si pt aceasta solutie dar am scris ca la-m ''batut'' acest sasiu...dar smd-uri nu exista....... [sasiu made in china].. Link to comment
cristronic Posted January 13, 2012 Share Posted January 13, 2012 Eu cred ca problema este de la tranzistoarele acelea cu care se face tensiunea de 5V si cea de 8V,defect tipic la acest sasiu. Link to comment
tehtronics Posted January 13, 2012 Share Posted January 13, 2012 schimba si tranzistoarele V501 si V502, din sursa Link to comment
cristi71 Posted January 13, 2012 Share Posted January 13, 2012 Eu cred ca problema este de la tranzistoarele acelea cu care se face tensiunea de 5V si cea de 8V,defect tipic la acest sasiu.am avut acest defect. schimbat tranzistorii pe 5v si nu a mai manifestat defectul. Link to comment
