H Robert Posted January 1, 2012 Share Posted January 1, 2012 Am si eu o problem ca un sistem 5.1 se aude un fel de "scartaituri" in difuzoare cand ascult muzica, ce ar putea avea? Link to comment
leoncris Posted January 1, 2012 Share Posted January 1, 2012 Zgomotul apare pe volum ... minim ?Ce placa de sunet ai ? Link to comment
H Robert Posted January 1, 2012 Author Share Posted January 1, 2012 La volum mic nu se aude dar cu cat cresc treptat volumul creste si acest zgomot, placa de sunet este incorporata in placa de baza, palaca de baza ete asrock alivedual-esata2 Link to comment
leoncris Posted January 1, 2012 Share Posted January 1, 2012 Aha , on bord.Incearca sistemul pe alt PC si daca'i OK , cumpara o placa de sunet de calitate,compatibila sistemului. Link to comment
H Robert Posted January 1, 2012 Author Share Posted January 1, 2012 Am incercat si la alt pc, tot aceleasi sunete se aud Link to comment
Dr.L Posted January 1, 2012 Share Posted January 1, 2012 De unde cresti volumul,din pc sau din sistem?Incearca si o alta sursa de semnal,preferabil un player portabil Link to comment
H Robert Posted January 1, 2012 Author Share Posted January 1, 2012 Si cand cresc volum din pc si cand cresc volumul de la sistem tot aceleasi zgomote se aud, am incercat si cu un mp3 si se aude aceleasi sunete, am filmat sa vedeti cum se aude http://www.youtube.com/watch?v=DeIBMyhS ... e=youtu.be Link to comment
Luca Posted January 2, 2012 Share Posted January 2, 2012 Face acelasi sunet imediat dupa ce il pornesti daca a stationat mult timp sau numai cand se incalzeste ? Link to comment
leoncris Posted January 2, 2012 Share Posted January 2, 2012 Asa se aude in toti satelitii,sau ...?Lasa doar satelitul cu mufa neagra si vezi daca merge asa apoi ii conectezi pe ceilalti,unul cate unu si vezi cum merge,sau,poti conecta fiecare satelit in mufa neagra ca acolo merg oricum pentru ca ala e pe mufa 3,5.Sau , poti lua un adaptor, bagi toate cinci mufele de la sateliti in el si din el sa iasa 2 mufe pe care sa le bagi in sistem in front left si right iar in placa de sunet sa baga doar firul verde.Sper ca am-am facut inteles. Link to comment
H Robert Posted January 2, 2012 Author Share Posted January 2, 2012 Face acelasi sunet imediat dupa ce il pornesti daca a stationat mult timp sau numai cand se incalzeste ?Si daca las sistemul ne alimentat o perioada de timp si il pornesc sa ascult muzica fara ca vreo componenta sa fie incalzita se aude.Se aude in toti satelitii si la subwoofer, si am observat cand dau la maxim subwoofer nu se mai aude deloc, are si scurte momente depinde de melodie se intrerupe sunetul in tot sisiemul si dupa acea revine, nu am incercat cu un adaptor dar nu cred ca o sa aiba vreun efect. Link to comment
H Robert Posted January 2, 2012 Author Share Posted January 2, 2012 Pai daca l-am conectat la un mp3 portabil de unde impamantare? Tot asa s-a comportat. Link to comment
H Robert Posted January 3, 2012 Author Share Posted January 3, 2012 Am gasit problema, eu mai demult am mai conectat la amplificatorul sistemului inca un subwoofer, si acum cateva saptamani l-am deconectat de la sistem dar am lasat firele ca am zis ca daca mai vreau sa il mai conectez vreodata sa fie acolo, si am lasat firele neizolate la capete si faceau contact una cu alta si din cauaza asta se auzeau acele sunete,s-a rezolvat, "se intampla si la case mai mari" Link to comment
