Guest paul46 Posted December 30, 2011 Share Posted December 30, 2011 Am un tv orion,care dupa cca.doua,trei ore dispare imaginea si apare o dunga alba pe orizontala.Dupa ce se raceste porneste din nou si dupa un timp apare dunga.Are cineva schema?Multumesc Link to comment
dan cod Posted December 30, 2011 Share Posted December 30, 2011 Ce latime are dunga?restul imaginii este neagra?Ceva defect in BV.Refa lipiturile la CIul de BV pentru inceput si schimba electroliticii de acolo. Link to comment
Guest paul46 Posted December 30, 2011 Share Posted December 30, 2011 Dunga are 2-3mm,vroiam schema sa vad Curile. Link to comment
tehtronics Posted December 30, 2011 Share Posted December 30, 2011 calitatea nu-i prea buna, dar poate te ajuta... T20MS.pdf Link to comment
