tiby_1981 Posted December 28, 2011 Share Posted December 28, 2011 Buna ziua.Am acest tv la reparat ca defect initial am avut finalul de linii 2SC5331 ars.Inainte de inlocuirea lui am inlocuit C519 4,7 micro/250V care era in mod evident uscat din el ramanand doar capsula metalica si 523 1micro/100V care era umflat.Corectia E-W este complet moarta,imaginea este foarte lata,din meniul de service nu se regleaza absolut nimic.Am masurat dupa schema fiecare componenta activa/pasiva din circuitul de E-W si nu am gasit nimic defect,toate componentele sant comform schemei.In colectorul tranzistorului de E-W BDX 53 am 1V.Intr-un capat la R519(2,2K ohmi),am 12V iar in celalalt capat am 11,2V.Este defect circuitul din partea digitala?Tranzistorul de E-W nu se incalzeste absolut deloc.Dioda dubla D505 intr-un capat am 135V iar in celalat capat am 1,5V care se gaseste si in colectorul tranzistorului de E-W.Rog o sugestie... Link to comment
leoncris Posted December 28, 2011 Share Posted December 28, 2011 http://www.eserviceinfo.com/downloadsm/ ... _22.1.html Link to comment
dan cod Posted December 28, 2011 Share Posted December 28, 2011 Ce tensiune este in punctul notat de mine? Link to comment
tiby_1981 Posted December 28, 2011 Author Share Posted December 28, 2011 1V.C521 680nf/250V l-am schimbat. Link to comment
dan cod Posted December 28, 2011 Share Posted December 28, 2011 Nu-i deloc in regula.Diodele sunt bune(aia dubla)?Acolo trebuie sa fie undeva pe la 32-35V cand este ok EWul.Deci ceva acolo este defect. Link to comment
tiby_1981 Posted December 28, 2011 Author Share Posted December 28, 2011 Ok.Dioda nu arata scurt-circuit insa o sa caut una noua sa o schimb.Prin tatonarea C521 se schimba dimensiunea imaginii insa E-W tot nu functioneaza. Link to comment
lefter Posted December 28, 2011 Share Posted December 28, 2011 verifica bobina de linga traf pote fi in scurt sau intrerupta Link to comment
tiby_1981 Posted December 28, 2011 Author Share Posted December 28, 2011 Prin decuplarea R516 care duce la E-W tensiunea care alimenteaza E-W ramane constanta 1V cu toate ca E-W nu este alimentat.O sa caut/comand o dioda dubla de E-W care sa sa aiba parametri identici/superiori diodei duble din tv. Link to comment
Guest Posted December 28, 2011 Share Posted December 28, 2011 de verificat totusi incalzirea lui L505;eu cred ca aceasta este de vinacand banuiti defectul in amplif E-W nu scoateti rezistenta serie cu bobina E-W ci colector/drena tranzistor forta(T505 aici) iar pe C523 trebuie sa apara 30-40v concomitent cu efect de perna Link to comment
tiby_1981 Posted December 28, 2011 Author Share Posted December 28, 2011 Se poate sa fiti mai explicit?Cu deconectarea rezistentei? Link to comment
tiby_1981 Posted December 29, 2011 Author Share Posted December 29, 2011 Dioda dubla este defecta.La masurarea pe scara de diode la aparat arata bine.Dar la masuratoarea de 200Mohmi arata rezistenta inversa.Asa e cand mai omiti ceva. Link to comment
