Jump to content
TV SAMSUNG CZ 21N112T
  • Replies 9
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Idei:1. Finalul nu se alimenteaza- verificati alimentarea, este o rezistenta mai mare, de putere, 2w, inainte de pinul pe care se aplica 12v, parca. Verificati R814 si R815. Eu am gasit arsa una din astea, la un tv. trasnit cu acelasi sasiu.2. Am gasit si tranzistorul care face mute ars, Q903.3 In cel mai rau caz si noul integrat final este defect, desi cam slabe sanse.Link cu alte discutii: viewtopic.php?f=17&t=38612Astept cu interes vesti!
Link to comment
Puteti incerca sa deconectati un terminal al R921, sa vedeti daca apare sonorul (zic si eu)
Deasemenea, cred ca ar fi bine de masurat si tensiunea in baza lui Q903 in cela doua stari, mute si normal, sa vedeti daca lucreaza procesorul.
Oricum, eu unul cred ca problema este pe circuitul e muting. Ar fi bine de verificat si Q905.
Iata ce spune datasheet+ul acestui integrat despre pinul MODE:
Mode selection
The TDA8943SF has three functional modes, which can be selected by applying the
proper DC voltage to pin MODE. See Figure 4 and 5 for the respective DC levels,
which depend on the supply voltage level. The MODE pin can be driven by a 3-state
logic output stage: e.g. a microcontroller with additional components for DC-level
shifting.
Standby — In this mode the current consumption is very low and the outputs are
floating. The device is in standby mode when (VCC - 0.5 V) < VMODE < VCC, or when
the MODE pin is left floating (high impedance). The power consumption of the
TDA8943SF will be reduced to <0.18 mW.
Mute — In this mode the amplifier is DC-biased but not operational (no audio output);
the DC level of the input and output pins remain on half the supply voltage. This
allows the input coupling and Supply Voltage Ripple Rejection (SVRR) capacitors to
be charged to avoid pop-noise. The device is in mute mode when
3 V < VMODE < (VCC - 1.5 V).
Operating — In this mode the amplifier is operating normally. The operating mode is
activated at VMODE < 0.5 V.
Din ultimul paragraf, eu inteleg ca daca tensiunea pe pinul Mode este mai mica de 0,5v, integratul ar trebui sa-si faca treaba si sa amplifice.
A, si o ultima sugestie pe care o am > Din cate retin, tv are jack pentru casti, care este montat lateral, alaturi de una din intrarile AV. Eu nu conectasem banda care duce la jack si nu mi-a mers sunetul, daca nu ma insel.
Succes!
Link to comment
apreciez interesul tau Marius!cum spuneam, Q903 masurat da bine , insa cand am masurat baza fata de masa :hopa! ->54 de ohmiverific schema si constat ca functia de muting se face din pinul 4 al UOC direct in baza Q903 da, ai ghicit rezistenta asta e data de un scurt in integrat..scot Q903 afara, (in acest fel tensiunea de MODE din pin 7 final audio scade, permitand acestuia sa devina operativ) si in acest moment sonorul aparechestia este ca nemaiavand functia de muting , la schimbarea canalelor se aude un pacanit deranjant, pe care nu stiu daca pot sa il suprim (cred ca nu)cam asta !spor!
Link to comment
Mda... cam neplacuta constatare..Oricum, inainte de a da verdictul final de procesor defect, v-as recomanda sa intrerupeti traseul de muting cat mai aproape de pinul procesorului care face aceasta functie (parca pinul 4 ati spus) si sa masurati si asa. Daca si in cazul acesta rezistenta este cea pe care ati spus-o nu mai incape nicio indoiala referitoare la procesor. Spun sa faceti asta deoarece se mai intampla ca la masurarea pe multimetru tranzistorul sa dea ok, iar in circuit sa-si faca de cap... Iar in privinta costului, am cumparat de pe la Iasi un proc cu 50 lei, cu tot cu taxe 60, nu e chiar ieftin.
Link to comment
Register a new account
Sign in
  • Create New...
Important Information
