Jump to content
Guest mondial4u
sistem alarma paradox
Guest mondial4u
salut cine ma poate ajuta si pe mine cu un sfat? am un sistem PARADOX DGP 848... si ma enerveaza ca scrie pe display numele fostei firme de paza, Si nu stiu codul de instalare m-ar interesa cum o pot reseta???
Link to comment
Share on other sites
Guest interitus
Scrie pe google "dgp 848 reference and installation manual" si descarca manualul de acolo.
Dupa ce resetezi centrala ... trebuie sa o reprogramezi. Daca nu stii sa o reprogramezi o sa ai o centrala NEFUNCTIONALA dar fara numele firmei de paza pe LCD'ul tastaturii. ;)
12.1 HARDWARE RESET
Performing a hardware reset will set all programmable sections
from [001] to [718] to default values, including the Installer Code
and System Master Code. Only the Panel ID, PC Password, PC
Telephone Number and Event Buffer will not be reset.
1) Make sure the Installer Code Lock is disabled (see section
12.4)
2) Remove the battery and AC power from the control panel.
3) Set the RESET jumper to on by placing a jumper on the reset
pins of the control panel.
4) Re-connect the AC power and the battery to the control panel.
5) Wait 10 seconds and remove the jumper.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
