petrenou Posted December 10, 2011 Share Posted December 10, 2011 pornesc tv si dupa o secunda intra in stand bypornesc si liniile,exista si fitu2 142v,u5 21v,u4 13v Link to comment Share on other sites More sharing options...
petrenou Posted December 10, 2011 Author Share Posted December 10, 2011 cum pot sa verific traf linii? Link to comment Share on other sites More sharing options...
DORFU Posted December 10, 2011 Share Posted December 10, 2011 il pornesti din telecomanda s-au din butonul de retea? Link to comment Share on other sites More sharing options...
BUGHIU Posted December 10, 2011 Share Posted December 10, 2011 cum pot sa verific traf linii?Cu testerul hr-diemen sau asa:viewtopic.php?f=17&t=62509&start=15&hilit=metode+verificare+trafo+linii Link to comment Share on other sites More sharing options...
petrenou Posted December 10, 2011 Author Share Posted December 10, 2011 din butonul de reteacand intra in stand by am pornit si din ch + si tot asa face Link to comment Share on other sites More sharing options...
DORFU Posted December 12, 2011 Share Posted December 12, 2011 Da-i un semnal av pe mufa euroscart dintr-un receptor de satelit si vezi ce face ,daca nu porneste atunci inseamna ca se protejeaza sursa ,ai consum mare si trebuie desfacut si reparat de cineva care se pricepe. Link to comment Share on other sites More sharing options...
petrenou Posted December 12, 2011 Author Share Posted December 12, 2011 daca pun un bec 60w pe alimentare aceasta functioneaza corect.as putea sa elimin comanda de stand by sa vad ce manifestare are? Link to comment Share on other sites More sharing options...
stefan35 Posted December 12, 2011 Share Posted December 12, 2011 Nu te supara, dar chiar trebuie sa iasa fum de undeva ca sa-ti dai seama de defect ? Ceva masuratori la rece ai facut ? Link to comment Share on other sites More sharing options...
petrenou Posted December 12, 2011 Author Share Posted December 12, 2011 tv porneste functioneaza bine dar nu se suprapun culorile pe verticala de sus in jos este rosu verde albastru Link to comment Share on other sites More sharing options...
leoncris Posted December 12, 2011 Share Posted December 12, 2011 Ia pune o poza ca m'ai ametit."Functioneaza bine , da' dupa o secunda intra in stand by " Link to comment Share on other sites More sharing options...
petrenou Posted December 12, 2011 Author Share Posted December 12, 2011 nu mai intra in stand by acuma merge bine dar de ex sigla tvr1 apare cu dubluri rosu sus verde un pic mai jos si albastru un pic mai jos Link to comment Share on other sites More sharing options...
leoncris Posted December 12, 2011 Share Posted December 12, 2011 Schimba .... PTC_ul . Link to comment Share on other sites More sharing options...
stefan35 Posted December 13, 2011 Share Posted December 13, 2011 Lasa-l 24 ore nealimentat si ai sa vezi cum o ia de la capat cu st/by-ul. Chiar nu vrei sa faci verificarile asa cum scrie la carte ? Mergi numai la plesneala ? Link to comment Share on other sites More sharing options...
Toni Marginean Posted December 13, 2011 Share Posted December 13, 2011 Probabil s-au miscat inelele de reglare a puritatii de pe gatul tubului! Link to comment Share on other sites More sharing options...
DORFU Posted December 13, 2011 Share Posted December 13, 2011 Sper ca nu ai umblat la bobina de deflexie,sa o desfaci de pe gitul tubului cinescop,asa cum spunea si domnul marginean s-ar putea sa se fi miscat magneti de convergenta de pe tubul cinescopic,la unele cinescoape sunt sigilate cu vopsea,la tuburile EAS este un inel magnetic de convergenta care este lipit cu un schoci.Te rugam sa ne spui daca s-a umblat la magneti si la deflexie. Link to comment Share on other sites More sharing options...
Archived
