claudiu68 Posted December 10, 2011 Share Posted December 10, 2011 salutare la toata lumea. am inlocuit bu 808 dfi cu 2sc 5388 inclusiv elco din baza. la pornire de la retea apare acea dunga laterala.am inlocuit si c 628 de 3,3 m cu 10m . refac din service faza ies cu stb. ok. functioneaza corect doar daca oprirea se face din tel. ce ar mai trebui schimbat sau inlocuit? Link to comment Share on other sites More sharing options...
dan-a2 Posted December 10, 2011 Share Posted December 10, 2011 Probabil tz. contrafacut ! viewtopic.php?f=17&t=74563 Link to comment Share on other sites More sharing options...
gabiTV Posted December 10, 2011 Share Posted December 10, 2011 verifica R634=10K !!! Link to comment Share on other sites More sharing options...
Guest stefano Posted December 10, 2011 Share Posted December 10, 2011 Pune bu 808df si dunga va disparea.Pentru varianta cu c5388 trebuie modificata o rezistenta dar nu am schema in fata.Daca nu te descurci fa-mi o solicitare. Link to comment Share on other sites More sharing options...
sorin0707 Posted December 10, 2011 Share Posted December 10, 2011 ce tensiune aveti pe pinul 49 la stv2246. Link to comment Share on other sites More sharing options...
cristronic Posted December 11, 2011 Share Posted December 11, 2011 R639 se modifica la valoarea de 10K. Link to comment Share on other sites More sharing options...
Archived
