Guest vicogeo Posted October 28, 2011 Share Posted October 28, 2011 Buna ziua, am descoperit ca am un cod de trouble 5 - "Bell Current Failure During an alarm, the bell output, which uses a fuseless circuit, will automatically shut down if the current exceeds its l imits. I f this occurs, the [5] button will illuminate. " de la ce sa apara acest cod? multumesc, George. Link to comment
Guest Posted October 28, 2011 Share Posted October 28, 2011 Nu ma pricep la alarme dar din textul in engleza inteleg ca centrala detecteaza o rezistenta prea mica, probabil un scurt circuit pe traseul care duce la sirena. Verifica daca sirena + firele pana la centrala sunt in regula. Link to comment
Guest vicogeo Posted October 29, 2011 Share Posted October 29, 2011 o alta persoana mi-a recomandat sa verific acumulatorul din sirena. Posibil sa fie terminat si electronica incearca sa-l incarce tragand mult curent peste nivelul normal. multumesc.G. Link to comment
