Vas Posted October 23, 2011 Share Posted October 23, 2011 In stand-by U1-130V,U2-14V.La pornire U1 scade la 30-40V,U2 la 2-3V,dupa care revine ,si TV ramane in stand-by.De cate ori incerci sa pornesti,se repeta acelasi lucru.Cu bec tensiuni normale, 118 si14.Tens.recuperate,si FIT incepi sa apare la pornire,nu este scurt masurabil in secundar traf linii.Tv s-a oprit in timpul mersului,deci cond. uscat exclus.Ramane traf linii defect.Singurul lucru suspect,tranzistorul final linii ramane rece,degeaba incerc pornirea de mai multe ori.Daca ar fi traf in scurt,ar terbui sa fie tranzistorul fierbinte.Eventual sursa se blocheaza asa repede,ca nu are timp sa se incinga? Link to comment Share on other sites More sharing options...
elmar Posted October 23, 2011 Share Posted October 23, 2011 Daca ar fi traf in scurt,ar terbui sa fie tranzistorul fierbinte.Eventual sursa se blocheaza asa repede,ca nu are timp sa se incinga?puneti in loc de R559(10/7w) una de 100/16w si observati ce se intimpla...(cit de repede si de tare se incalzeste aceasta rez si final linii) Link to comment Share on other sites More sharing options...
Vas Posted October 23, 2011 Author Share Posted October 23, 2011 Am pus o rez. 100ohm,nu mai blocheza sursa.Inainte de rez. 107V,dupa 40V.Rezistenta se incinge repede,nici nui de mirare.Dupa mai multe in cercari deja incepe sa se incalzeasca si traful in partea de jos. Interesant insa,finalul linii si acum este rece.Deci traf linii nou.Mersi Elmar pentru ajutor. Link to comment Share on other sites More sharing options...
Vas Posted October 23, 2011 Author Share Posted October 23, 2011 Am cautat pe Net,si imi da echivalent FBT8030.Asa si este oare? Link to comment Share on other sites More sharing options...
Toni Marginean Posted October 23, 2011 Share Posted October 23, 2011 Asa este: Beko 12.1 este echipat cu urmatoarele tipuri de trafo linii - HR(FBT)8030, HR8043, HR8881, HR8051, HR8954 si HR8008. Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 23, 2011 Share Posted October 23, 2011 Am cautat pe Net,si imi da echivalent FBT8030.Asa si este oare?Va salut ! Daca ne spuneti ce scrie pe acel traf original,poate va ajutam cu echivaletul lui,ca asa pentru acest sasiu 12.1 sunt cam multe echivalente.Asteptam ! Link to comment Share on other sites More sharing options...
Vas Posted November 1, 2011 Author Share Posted November 1, 2011 Am primit traful-FBT8030,am montat,TV porneste,dar rastru deplasat in jos.Am incercat sa intru in SM,dar nu pot.Nu reusesc cu Contrast -,cu 8500 sau 9301.Inca un lucru,pe imagine apar linii verticale,care se modifica ca un VU-metru,si se schimba numarul lor aleatoriu.Cel mai des apare in partea de jos,de la mijloc la dreapta.Ma gandesc ca poate dispari,daca reusesc sa reglezi rastrul la mijloc.Procesorul este ST6387.M-as bucura de o idee de intrare in SM. Link to comment Share on other sites More sharing options...
Toni Marginean Posted November 1, 2011 Share Posted November 1, 2011 Daca ati avea revista Depanatorul v-ati descurca! Una din modurile de intrare in SM ar fi: cu o telecomanda P657 - SER In=tasta OSD, SER OUT = tasta AV, memorare cu tasta ANA.M cu tastele 1 si 6, 2 si 7, 3 si8, 4 si 9 se regleaza geometria. Link to comment Share on other sites More sharing options...
mariancalinescu Posted November 1, 2011 Share Posted November 1, 2011 Cel mai simplu mod de intrare in service meniu la Beko 12.1 este prin apasarea tastei "Sleep" de pe o telecomanda N18 (Ivory,Tauras,Provision-sasiu TV2K ). Liniile verticale negre care va apar pe imagine sunt din cauza trafo china de slaba calitate.Am intalnit aceeasi manifestare la Beko diag.66cm cu trafo.FBT 7218. Puteti monta trafo recuperat HR8051 sau HR8484-se gasesc pe placile Beko mai noi (de dimensiune mica) gen 12.5,12.6,12.8 etc. Link to comment Share on other sites More sharing options...
ROBEERT Posted November 1, 2011 Share Posted November 1, 2011 Cel mai simplu mod de intrare in service meniu la Beko 12.1 este prin apasarea tastei "Sleep" de pe o telecomanda N18 (Ivory,Tauras,Provision-sasiu TV2K ). Liniile verticale negre care va apar pe imagine sunt din cauza trafo china de slaba calitate.Am intalnit aceeasi manifestare la Beko diag.66cm cu trafo.FBT 7218. Puteti monta trafo recuperat HR8051 sau HR8484-se gasesc pe placile Beko mai noi (de dimensiune mica) gen 12.5,12.6,12.8 etc.Hai sa zici ca daca pui FBT la tuburile de 90 grade o mai scalzi cat de cat ( chiar poate sa functioneze pana imbatranesc nepotii ), dar daca ai pus FBT pe tub de 110 grade, s-a cam terminat filmul ( ai ocazia sa-ti crape poate dupa cateva zile ). Link to comment Share on other sites More sharing options...
dan cod Posted November 2, 2011 Share Posted November 2, 2011 Verificati recuperatele de alimentare video si BV o sa vedeti ca sunt aiurea.Se poate ajusta cu rezistente. Link to comment Share on other sites More sharing options...
doru tv Posted November 2, 2011 Share Posted November 2, 2011 inlocuiti chinezaria cu ceva de calitate Link to comment Share on other sites More sharing options...
Vas Posted November 2, 2011 Author Share Posted November 2, 2011 Liniute am gasit mai demult la TV Telefunken de 110 grade,cu traf original in el.La Beko daca maresc UG2,se reduce numarul liniilor,sau nu se vad.Cateodata dispari de tot.Daca a-si fi avut din recuperari,nu mai luam nou.Am trafuri la care tensiunile ari fi bune,dar pinii nu corespund ca distanta.Luam ceva mai bun traf,dar clientul a spus,daca costa mai mult,renunta la reparat.La pret de 19 lei nici nu poti sa ai mari pretentii. Link to comment Share on other sites More sharing options...
Archived
