ivanflorin Posted October 21, 2011 Share Posted October 21, 2011 am acest tv(nu l-am deschis sa vad sasiul)...nu are sunet deoarece nivelul volumului nu actioneaza decit foarte putin(celelante functii regleaza normal)probabil ms,memorie....ma ajuta cineva ,multumesc anticipat... Link to comment Share on other sites More sharing options...
dan cod Posted October 21, 2011 Share Posted October 21, 2011 Este sasiu anubis aac si este probabil in mod hotel .Cate taste are pe panoul frontal? Link to comment Share on other sites More sharing options...
ivanflorin Posted October 21, 2011 Author Share Posted October 21, 2011 3 taste...nu stiu de ce nu pot trimite direct raspunsul,ms Link to comment Share on other sites More sharing options...
zvasile Posted October 21, 2011 Share Posted October 21, 2011 3 taste...nu stiu de ce nu pot trimite direct raspunsul,msspune si terminatia la procesor... P.S/;pentru a posta in subiectul deschis de tine ,trebuie sa folosesti functia raspunde Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 21, 2011 Share Posted October 21, 2011 Va salut ! Da asa este, este vorba de sasiu anubis aac.Daca aveti nevoie de service manual + schema,o aveti de la mine schema cadou,iar service manual luati-l de aici : http://elektrotanya.com/philips_anubis_ ... nload.html. Succes !!! Link to comment Share on other sites More sharing options...
dan cod Posted October 21, 2011 Share Posted October 21, 2011 Nu are cde face cu schema Florine in cazul asta.sunt mai multe posibilitati de dezactivare.1.Se comuta pe programul 38 si se apasa simultan select de pe panou si sleep timer de pe telecomanda cam 5-6 secunde.1.Se comuta pe programul 38 si se apasa meniu de pe panou si sleep timer de pe telecomanda simultan tot asa 5-6 secunde. Link to comment Share on other sites More sharing options...
ivanflorin Posted October 21, 2011 Author Share Posted October 21, 2011 procesor TMP47P834N si sub 9407eai daca e necesar Link to comment Share on other sites More sharing options...
zvasile Posted October 21, 2011 Share Posted October 21, 2011 procesor TMP47P834N si sub 9407eai daca e necesarincearca cum a zis Dan1.Se comuta pe programul 38 si se apasa simultan select de pe panou si sleep timer de pe telecomanda cam 5-6 secunde.1.Se comuta pe programul 38 si se apasa meniu de pe panou si sleep timer de pe telecomanda simultan tot asa 5-6 secunde. Link to comment Share on other sites More sharing options...
ivanflorin Posted October 21, 2011 Author Share Posted October 21, 2011 nu vrea cu 38,select,timer Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 21, 2011 Share Posted October 21, 2011 nu vrea cu 38,select,timerTelecomanda este originala a tv-ului sau una universala ?Ateptam ! Link to comment Share on other sites More sharing options...
dan cod Posted October 21, 2011 Share Posted October 21, 2011 Nu 3,8 select timer ci pui TVul pe programul 38 si apoi apesi ce am spus eu. Link to comment Share on other sites More sharing options...
ivanflorin Posted October 21, 2011 Author Share Posted October 21, 2011 sigur,l-am pus pe pr38 si simultan select si timer dar telec nu este origiala Link to comment Share on other sites More sharing options...
dan cod Posted October 21, 2011 Share Posted October 21, 2011 Telecomanda face sleep timer?ca asta se poate verifica.Daca nu face degeaba apesi pe tasta aia. Link to comment Share on other sites More sharing options...
Archived
