Mircea AR Posted October 20, 2011 Share Posted October 20, 2011 Buna ziua.Va rog daca se poate sa-mi spuneti ce sasiu ar fi la TV color crt PHOCUS TV 20S.Are in componenta urmatoarele:proc si jungla STV 2246H, SDA 5535 A071,sunet TDA2822, in alimentare TDA1684 P si tranzitor K 2750 iar final linii BU 508 DFI.Pe sasiu exista o eticheta de hartie pe care scrie: C1 20 HL1 P BG TXT 2HP NTSC Z A OFF.Va rog astept raspuns.Daca trebuie alte date desi nu stiu ce ar m-ai putea sa fie va rog intrebati-ma. Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 20, 2011 Share Posted October 20, 2011 Cred ca este vorba de sasiu 12.8. :daSucces ! Link to comment Share on other sites More sharing options...
leoncris Posted October 20, 2011 Share Posted October 20, 2011 BEKO ELEKTRONIK 12.6 Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 20, 2011 Share Posted October 20, 2011 BEKO ELEKTRONIK 12.6Acum ateptam informatia domnului Mircea AR care este sasiul corect ! Link to comment Share on other sites More sharing options...
leoncris Posted October 20, 2011 Share Posted October 20, 2011 La 12.6 - SDA5535...La 12.8 - SDA5552...Dar cum te pricepi tu la TV_uri , nici nu'i de mirare. :aut:Si mai dai si ..."sfaturi " . Mama ei de electronica ! Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted October 20, 2011 Share Posted October 20, 2011 Va salut ! Scuze ca intervin din nou,va rog ff mult ca sa cititi si dvs pe acest licnk : viewtopic.php?f=17&t=12909&start=45 ce a scris domnul Tavi. A si inca ceva unde vedeti dvs la acest sasiu 12.6 integratul de sunet TDA2822 si cu jungla STV 2246H,ma refer pe schema ? Link to comment Share on other sites More sharing options...
Mircea AR Posted October 20, 2011 Author Share Posted October 20, 2011 Va rog nu va certati, oricum defectul este in alimentare.Inculpatul pare a fi TDA 16 846P defect.Sursa nu porneste.Va multumesc pt ajutor si o sa va spun rezultatul dupa ce schimb TDA respectiv.( Oricum nu este nici una din scheme corecta, este o combinatie de scheme),oricum m-ati ajutat foarte mult cu aceste scheme. Link to comment Share on other sites More sharing options...
dan cod Posted October 20, 2011 Share Posted October 20, 2011 Vedeti ca este acolo o rezistenta de 3m9 care se tot intrerupe.Verificati-o aia inainte de a schimba CIul. Link to comment Share on other sites More sharing options...
Mircea AR Posted October 21, 2011 Author Share Posted October 21, 2011 Maine innainte sa schimb CI voi verifica mai atent si cele 2 rez de 3M9 si 1M si va voi comunica.Acum dupa masa am cumparat si CI respectiv.Maine daca vom trai vom vedea.Decedatul a reanviat.Rez de 3M9 si 1M au fost bune defect a fost CI din alimentare cu scurt intre pinii 12 si 13( 12 masa, 13 comanda la mosfet).Va multumesc tuturor pt ajutor si spor in afaceri. Link to comment Share on other sites More sharing options...
Archived
