Jump to content
Vw gamma V by technisat
criss
Buna ziua,
Am primit un vw gamma 5 produs de technisat. Doresc sa ii atasez un mp3 player pe intrarea de la CD-Player/changer.
Am gasit pe net cateva descrieri pt alte modele de vw, seat, audi care au aceeasi conector dar din pacate nu mi-a functionat.
Activare cd-player: Pini 13 si 14 le-am conectat impreuna.
Iar pini 18(masa),19(Stanga),20(dreapta) sunt pt semnalul audio.
Posted Image
Acest radio/casetofon provine de pe un vw passat B5.5 din 2004 si avea conectat cdplayerul original.De aceea ma gandesc ca nu trebuie activat aceasta oprinune prin magistrala CAN.(Am un vw polo 6N2 pe CAN)
VW Radio Systems Generation 5 (Gamma/Premium)
Coding
??xxx: Sound-Adjustment
00 = Standard/Other
01 = Golf (1J)
02 = Bora/Jetta (1J/9M)
03 = Golf/Bora/Jetta Variant (1J)
04 = Passat Limousine (3B)
05 = Passat Variant (3B)
06 = Lupo/Polo (6X/9N)
07 = Golf-Cabriolet (1E)
08 = Sharan (7M) & New Beetle (1C)
09 = Transporter/Caravelle (7D)
xx?xx: Speakers
0 = No passive Speakers (Sound System)
2 = 2 passive Speakers (Front)
3 = 2 passive Speakers (Rear)
4 = 4 passive Speakers (Front and Rear)
xxx?x: Sound System Correction
0 = Sound System not installed (No Correction)
1 = Sound System (Bose) installed
2 = Sound-System (DSP) installed
3 = Monsoon (2-door)
4 = Monsoon (4-door)
xxxx?: Configuration
+1 = Active/Remote Supplied Antenna
+2 = CD-Player/Changer (including builtin CD)
+4 = Secondary Display (Instrument Cluster)
Link to comment
Share on other sites
  • Replies 3
  • Created
  • Last Reply
totusi am rulat o diagnosticare pe casetofon:
Monday,10,October,2011,15:02:25:10074VCDS Version: Release 10.6.4Address 56: Radio Labels: 1J0-035-18x-56.lblControl Module Part Number: 1J0 035 186 DComponent and/or Version: Radio YD5 0004Software Coding: 04403Work Shop Code: WSC 05311 VCID: 2647F2ABE8773 Faults Found:0 - Connection to Speaker Rear Left 36-00 - Open Circuit1 - Connection to Speaker Rear Right 36-00 - Open Circuit00855 - Connection to CD changer 49-00 - No Communications
Fiind un polo doar 2 difuzoare are in fata asa ca am setat casetofonul pt doua difuzoare:Software Coding: 04203Acuma doar ultima eroare, cea referitor la cd-changer mai are.
Link to comment
Am pus osciloscopul la lucru dar nu prea multe am obtinut rezultatul asteptat.
Atasez cateva poze:
Data out (pinul 14)
Posted Image
Posted Image
Clock (pinul 15)
Posted Image
Posted Image
Acuma nu stiu daca intradevar sunt activate sau nu. cand pornesc radio atunci imi apar ca si in pozele anterioare. testerul osciloscopului l-am conectat direct pe pin ca sa nu mai apara perdurbatii.
din pacate nu am magazie de cd sau cdplayer pt a o conecta si atuncea sa masor.
Stie cineva cum as putea activa iesirile de date?
Link to comment
Archived
  • Create New...
Important Information
