Guest enjoy_clvb Posted February 17, 2015 Share Posted February 17, 2015 (edited) am masurat pe cea verticala 470 ohmi. pe cealalta am 810 ohm. il bag acum in proba sa vad daca s-a mai rezolvat ceva, ca am mai schimbat niste rezistente pe ici pe colo Edited February 17, 2015 by enjoy_clvb Quote Link to comment Share on other sites More sharing options...
Guest cata82 Posted February 17, 2015 Share Posted February 17, 2015 Cu siguranta nu masori bine deloc bobina de deflexie!Valoarea bobinei verticale este undeva intre 11-13,5 ohmi iar cea orizontala intre 2,5-4 ohmi!Nu o sa vezi NICIODATA bobina de deflexie cu valorile acelea de 470 ohmi respectiv 810 ohmi, la niciun tv crt! Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted February 17, 2015 Share Posted February 17, 2015 (edited) pe schema am doua tranzistoare finale catre una din mufe bd228 si bd229, cred ca e avariat unul de asta. Am mai observat si un rezistor care duce catre mufa respectiva, smd de 180k, masurat are ~30k, o fi si asta implicat, am sa-l schimb Am masurat 470 ohmi am pe deflexie, iar pe bobina corespunzatoare 10 ohmi nu are cum sa aibe pe bobina deflexie 470 omi pe B+ ce tensiune este? Edited February 17, 2015 by Harhas Florin Quote Link to comment Share on other sites More sharing options...
dan cod Posted February 18, 2015 Share Posted February 18, 2015 E bun aparatul de măsură?nu-i defect?Daca e bun greșești măsurătorile de numa. Quote Link to comment Share on other sites More sharing options...
giany Posted February 18, 2015 Share Posted February 18, 2015 vezi ce optocuplor ai pus acolo cnx sau cny stiu ca am avut acest defect cand am inlocuit cu un alt optocuplor decat cel initial Quote Link to comment Share on other sites More sharing options...
alex_serv57 Posted February 18, 2015 Share Posted February 18, 2015 verifica : c 2402 , 2401, 2401 , 2422 ,2420 ; r 3405 , 3402 , 3404 ; Q 7402, 7401 . Eu zic sa lasi optocuplorul in pace atata timp cat ai tensiunile bune in secundarul sursei .. salutare Quote Link to comment Share on other sites More sharing options...
dan cod Posted February 18, 2015 Share Posted February 18, 2015 la L6.1 optocuplorul nu este pentru reglaj U1 Quote Link to comment Share on other sites More sharing options...
giany Posted February 18, 2015 Share Posted February 18, 2015 la philips l6.1 optocuplorul da start la tranzistor prefinal linii si pare defect de oscilator si prefinal linii si nu de vertical cum inicati Quote Link to comment Share on other sites More sharing options...
Guest enjoy_clvb Posted February 18, 2015 Share Posted February 18, 2015 Am inlocuit un octocuplor cny17f-2 tot cu acelasi model, am sa il mai schimb inca o data poate nu s-a nimerit bun.. sau incerc si un cnx. Scz pt masuratori la bobinele de deflexie, au 11ohmi si 2 ohmi, n-au de ce sa fie defecte bobinele, ca au functionat inainte sa-i schimb octocuplorul. B+ nu stiu care este, sa-l masor. Voi lua in calcul toate mesajele primite si va multumesc Quote Link to comment Share on other sites More sharing options...
dan cod Posted February 18, 2015 Share Posted February 18, 2015 95V este U1 la L6.1 Quote Link to comment Share on other sites More sharing options...
Depanatoru Posted February 18, 2015 Share Posted February 18, 2015 Parca e de la optocuplor necorespunzator defectul asta cu dunga pe mijloc , asa-mi amintesc , ca s-au rarit mult L6.1 Quote Link to comment Share on other sites More sharing options...
Guest enjoy_clvb Posted February 19, 2015 Share Posted February 19, 2015 i-am pus optocuplorul original ( cel care porneste mai greu dupa ce se incalzeste) si nu mai face dunga aia pe mijloc, deci de la optocuplor se tragea. am sa mai cumpar si din alte locuri optocuploare sa vad rezultatul. Oricum problema s-a rezolvat, nici eu nu am banuit ca poate fi de la asta. Multumesc pt clarificari Quote Link to comment Share on other sites More sharing options...
Join the conversation
