Guest ICHIM Posted November 8, 2010 Share Posted November 8, 2010 Se pricepe cineva la Candy c105 si whirpool AWM820 Link to comment
Guest ICHIM Posted November 8, 2010 Share Posted November 8, 2010 Ma intereseaza schemele amindurora...Dar in principal cea pentru Candy ...Pina atunci merge si semiautomata...Cu ceva tre' sa-mi spal rufele...Va rog sa ma ajutati cu schemele si unde pot gasi si modulele electronice de schimb...sau, Candy porneste pe un program, oricare selectat si se opreste dupa citeva secunde...Am desfacut zavorul cu bimetalul, dar nu inteleg ce fel de rezistenta este acea pastila aflata intre lamelele bimetalului...termistor cumva ? Si luate separat cu bypass se comporta la fel...stiu ca e un contact NC unul ,NO , dar nu inteleg care e treaba cu ,,pastila'''...daca as avea o schema , lucrurile s-ar limpezi... Ceva,, ingenuchiaza modulul electronic de comanda... triacul comanda releul si ,,se debranseaza dupa citeva secunde de program de la 220v. Link to comment
quadrall Posted November 9, 2010 Share Posted November 9, 2010 asa arata candy ? iar celalalt fisier este whirpool Link to comment
Guest ICHIM Posted November 9, 2010 Share Posted November 9, 2010 Nu..dar o sa-i fac o poza si-ti-o arat...totusi iti multumesc ca mi-ai raspuns...pastram legatura..Multumesc ! Link to comment
Guest ICHIM Posted November 12, 2010 Share Posted November 12, 2010 aici este masina candy c105 Link to comment
Guest ICHIM Posted November 12, 2010 Share Posted November 12, 2010 iar aceasta este 'masca' de wirlpool situata in fata masinii de spalat,este momentan demontata si am fotografiat doar aceasta parte Link to comment
Guest ICHIM Posted November 14, 2010 Share Posted November 14, 2010 HAI ..BRE CE FACETI...V-ATI INCURCAT RAU...!? Link to comment
cosmos Posted November 19, 2010 Share Posted November 19, 2010 Ma intereseaza schemele amindurora...Dar in principal cea pentru Candy ...Pina atunci merge si semiautomata...Cu ceva tre' sa-mi spal rufele...Va rog sa ma ajutati cu schemele si unde pot gasi si modulele electronice de schimb...sau, Candy porneste pe un program, oricare selectat si se opreste dupa citeva secunde...Am desfacut zavorul cu bimetalul, dar nu inteleg ce fel de rezistenta este acea pastila aflata intre lamelele bimetalului...termistor cumva ? Si luate separat cu bypass se comporta la fel...stiu ca e un contact NC unul ,NO , dar nu inteleg care e treaba cu ,,pastila'''...daca as avea o schema , lucrurile s-ar limpezi... Ceva,, ingenuchiaza modulul electronic de comanda... triacul comanda releul si ,,se debranseaza dupa citeva secunde de program de la 220v.Pastila aceea este o rezistenta care incalzeste lamelele alea pe care le vezi acolo, acestea la o anumita temperatura cupleaza un contact (ca la termostatul un fier de calcat) apoi trimite tensiune mai depare spre modul, totodata zavoraste incuietoarea hubloului. Link to comment
Guest ICHIM Posted November 24, 2010 Share Posted November 24, 2010 Multumesc mult !Se cunoaste cine-i mester in asa ceva!Nu aveti cumva si o schema de candy c105 , whirpool AWM820 ? sau un lynk ceva... Link to comment
doru3160 Posted November 24, 2010 Share Posted November 24, 2010 Pastila aceea este o rezistenta care incalzeste lamelele alea pe care le vezi acolo, acestea la o anumita temperatura cupleaza un contact (ca la termostatul un fier de calcat) apoi trimite tensiune mai depare spre modul, totodata zavoraste incuietoarea hubloului.Daca nu exista copii mici care sa umble accidental la masina de spalat in timpul functionarii,se poate lesne renunta la acel sistem,eu am facut-o si nu am avut nici un fel de problema,si nu pt ca s-a defectat,ci pt ca mergea prea bine...dupa terminarea ciclului de spalare,trebuia asteptat vreo 3-4 min pana sa se raceasca sistemul si sa se poata umbla la masina...lucru pe care l-a reclamat "operatorul" si eu m-am conformat Se leaga direct firele ce vin pe contact,iar cel de la alimentarea pastilei se izoleaza(fiind element de siguranta,normal ca fiecare o face pe raspunderea lui) Link to comment
tv1 Posted November 24, 2010 Share Posted November 24, 2010 Multumesc mult !Se cunoaste cine-i mester in asa ceva!Nu aveti cumva si o schema de candy c105 , whirpool AWM820 ? sau un lynk ceva...Whirlpool AWM820 service manual in atasament Link to comment
Guest ICHIM Posted November 24, 2010 Share Posted November 24, 2010 multumesc ..sunteti tari...daca are cineva si schema de candy c105...ar fi super...multumesc inca odata... Link to comment
