Guest Kyro Posted October 4, 2005 Share Posted October 4, 2005 Stie cineva cum se poate activa meniul de service pt un televizor Toshiba 21S23E2 ? Link to comment
Tavi Posted October 4, 2005 Share Posted October 4, 2005 pai daca e sasiu de orion ( ca detalii despre tv e greu sa dati , doar asteptati raspunsuri :axe: ) cu procesor OEC , faci in felul urmator :volum la minim , apoi apasat simultan VOL - de pe tv impreuna cu tasta 9 de pe telecomanda Link to comment
Guest Kyro Posted October 4, 2005 Share Posted October 4, 2005 Nu merge... Nu stiu prea multe despre el dak te ajuta link asta http://www.eplus.hr/3-izlistgrupe.asp?xsifra=21S23E2 Link to comment
belowsky Posted October 5, 2005 Share Posted October 5, 2005 nu stiu daca te ajuta dar poti sa incerci .Toshibaa2150S5ECTVService ModePress 'MUTE' button. Press and hold 'MUTE'button and press 'MENU' on local keyboard.Select: PR nr.. Adjust: VOL+/-. Store: auto.Exit: 'STANDBY'. Test picture: 'AV'.Toshiba2876DD2988DGCTVService ModePress 'MUTE' button. Press and hold 'MUTE'button and press 'MENU' on local keyboard.Select:PR+/-.Adjust:VOL+/-.Store:auto.Exit:'STANDBY'. Test picture: 'AV'. succes. :smt007 Link to comment
Guest Kyro Posted October 13, 2005 Share Posted October 13, 2005 Da pana la urma era "volum la minim , apoi apasat simultan VOL - de pe tv impreuna cu tasta 9 de pe telecomanda" doar k nu am tinut eu destul... 10x Tara Dak mai are nevoie cineva de manualul detaliat http://www.denom.com/schematic.asp?id=2566... e pentru toshiba 21S23F dar nu am observat mari diferentze... Link to comment
Guest Posted April 19, 2012 Share Posted April 19, 2012 Va salut, Are cineva valorile reglajelor normale (din fabrica) din meniu service la acest TV ? Am vrut sa reglez culorile din meniu si [*] mi-am prins urechile in el[*] Prostia mare a fost ca nu mi-am notat valorile. Link to comment
