Guest pantileionut Posted September 17, 2010 Share Posted September 17, 2010 am si eu un monitor lcd rpc de 19 inch si am o problema cu el....dupa 3 secunde de la pornire se inchide lampile (lumina din spatele dispay) care lumineaza ecranul.....dak il inchizi si dai drumul din nou merge iar 3 secunde..... dak luminezi dispay cu o lanterna se vede ceva imaginea.. Link to comment Share on other sites More sharing options...
FLORINV69 Posted September 17, 2010 Share Posted September 17, 2010 invertorul sau una din lampi dusa! Link to comment Share on other sites More sharing options...
Guest pantileionut Posted September 17, 2010 Share Posted September 17, 2010 si cum pot sa-mi dau seama care din ele e problema?? lampile se mai pot schimba??? Link to comment Share on other sites More sharing options...
Guest pantileionut Posted September 17, 2010 Share Posted September 17, 2010 monitorul are toane cnd merge bine cu zilele sau cand face figuri de sta ori 3 secunde ori 10 secunde aprins. sa fie lampile arse sau doar o problema de condesantoare pe partre de inalta??? Link to comment Share on other sites More sharing options...
mely17 Posted September 18, 2010 Share Posted September 18, 2010 E mai mult ca sigur sunt cateva neone duse! Desfa ecranu si vezi in ce stare sunt neoanele! Inainte verifica daca ai tensiune de alimentare pe inverter! Link to comment Share on other sites More sharing options...
Guest pantileionut Posted September 18, 2010 Share Posted September 18, 2010 am sa desfac mai tarziu ecranul....si inca ceva in alea 3 secunde de functionare imaginea are o noanta rosiatica.... banuiesc ca e de la lampi nu se apind cum trebuie Link to comment Share on other sites More sharing options...
Guest pantileionut Posted September 18, 2010 Share Posted September 18, 2010 am revenit cu niste poze in tottal sunt 4 tuburi mici din care ......2 tuburi crapate in interior... iar celalalte doua au ceva negreala la capete... stie cineva unde gasesc tuburi din astea?? lungime 415 mm (aproximativ....nu stiu exact cum se masoara) grosime 2 mm Link to comment Share on other sites More sharing options...
krotal Posted September 18, 2010 Share Posted September 18, 2010 Incearca la Telezimex Link to comment Share on other sites More sharing options...
bogdy88 Posted September 18, 2010 Share Posted September 18, 2010 Chiar nu ai un panou de 19" defect sau part din care sa sa poti lua neoanele? La telezimex unele preturi nu se justifica.Daca esti cumva din Cluj te ajut eu cu un panou din care sa iei neoanele. Link to comment Share on other sites More sharing options...
Guest pantileionut Posted September 18, 2010 Share Posted September 18, 2010 eu aku ma gndeam sa incerc sa fac alceva....sa fac cu leduri....aku unde gasesc eu leduri albe mici si oarecum un pret rezonabil..... Link to comment Share on other sites More sharing options...
Archived
