Guest yryss Posted September 10, 2010 Share Posted September 10, 2010 Buna,sunt nou pe forum dar va urmaresc ori de cate ori am nevoie , acum am o problema cu un monitor lcd-GNR TS 702 17''- se manifesta astfel-la deschidere se aude un bzzzzzz circa 2 sec. pe urma dispare imaginea-am desfacut monitorul 'bucati' si in partea de sus 1 lampa din cele 2 era sparta , avetzi idee daca ar putea sa mearga si asha cu ceva artificii aduse sau nu se poate pacali invertorul si daca se poate ce ar trebui sa fac. Multumesc Link to comment Share on other sites More sharing options...
bobo Posted September 10, 2010 Share Posted September 10, 2010 nu are 4 lampi?viewtopic.php?f=17&t=66237 Link to comment Share on other sites More sharing options...
Guest yryss Posted September 10, 2010 Share Posted September 10, 2010 Are 2 lampi sus si 2 jos. Link to comment Share on other sites More sharing options...
bobo Posted September 10, 2010 Share Posted September 10, 2010 ok.intelesesem ca are doar 2 lampi ceea ce mi se pare ciudat.cele de 15inch au 2 lampi iar cele de 17inch au 4 lampi.cu ce contoler este invertorul ?cu ce este echipata sursa?.denumirea completa a placii sursa+invertor pt a gasi o schema. Link to comment Share on other sites More sharing options...
Guest yryss Posted September 10, 2010 Share Posted September 10, 2010 multumesc pentru interes, cand ajung acasa am sa trimit si acele date despre sursa + invertor. Link to comment Share on other sites More sharing options...
Guest yryss Posted September 14, 2010 Share Posted September 14, 2010 Uraaa, am reusit aseara sa il fac , am primit lampile prin curierat- ma asteptam sa fie bucati dar erau cat se poate de intregi - am schimbat ambele lampi si acum functioneaza ca nou , este primul monitor facut de mine,am mai reparat TV,Radio, si alte alea .multumesc pentru solutii de rezolvare a problemei. Link to comment Share on other sites More sharing options...
bobo Posted September 14, 2010 Share Posted September 14, 2010 poti sa-mi zici si mie de unde le-ai cumparat?astept mesaj privat.multumesc. Link to comment Share on other sites More sharing options...
Guest freeborn Posted September 14, 2010 Share Posted September 14, 2010 Buna ziua, am gasit forumul cautand dupa informaitii depsre un monitor laptop. Poata sa-mi spuna cineva daca jumatatea unui monitor laptop se vede OK, si cealalta jumatate e asa mai intunecata . oare invertorul e problema sau lampile ? Multumesc , cu stima . E un laptop Fujitsu Siemens Amilo si ceva Oare cate lampi sant in LCD ul respectiv. Link to comment Share on other sites More sharing options...
Archived
